928 Forum 1978-1995
Sponsored by: 928 Specialists
Long rods for stroke increase
Old Sep 25, 2005 | 08:09 PM
G Man's Avatar
G Man
Default Long rods for stroke increase
I read some time ago ( before I had my 928 ) about Ford guys building " long rod" engines. Instead of doing the whole crank,rod,piston thing to build a stroked engine, they were simply using longer rods and custom pistons with the wrist pin in a different location.From what I remember the results were good. Would this method be possible in the 928 engine? Seems like it might work if there is room for this type of mod.
Old Sep 25, 2005 | 08:14 PM
slate blue's Avatar
slate blue
You are missing a key ingrediant, you must change the stroke. What you have alluded to is a change in the rod to stroke ratio.
Old Sep 25, 2005 | 08:34 PM
GlenL's Avatar
GlenL
Greg is correct: If you don't change the crankshaft the stroke, and displacement, will be the same. Maybe get some more power through changing geometries and getting a better mechanical advatage with a longer rod.
Old Sep 25, 2005 | 08:46 PM
FlyingDog's Avatar
FlyingDog
They're probably bumping up the compression ratio while increasing the rod to stroke ratio.
Old Sep 26, 2005 | 12:04 AM
TAREK's Avatar
TAREK
I'm guessing what is meant is combining the longer rod with the stroker crank in order to maintain compression ratio.....I think
Old Sep 26, 2005 | 04:47 AM
SharkSkin's Avatar
SharkSkin
My Dad was a Ford guy since "sleeper" meant dropping a flathead V8 in a model T and running one exhaust manifold into a super-quiet muffler and the other through the stock exhaust(so it would still sound like a stock T until it baked the tires off) so I've had an earful(or two) of this stuff.
Early Ford slugs tended to be pretty heavy. There was a huge lump of useless metal between the wrist pin and the crown. Long-rod conversions were done on engines that were built to rev(opposite of stroker) because the shorter piston/longer rod made for a lighter assembly overall. This sort of thing was common in race classes that did not allow displacement changes but where every last pony needed to be extracted.
