928 Forum 1978-1995
Sponsored by: 928 Specialists
Injector ?
Old Aug 31, 2005 | 01:37 PM
worf928's Avatar
worf928
Gordon, should we assume that you are associated with the organizations featured on the web sites in your sig?
If so, I notice that the injector services include replacement of the o-rings. Can you comment on if Injector Services can or does replace the o-rings of 928 injectors with the correct Porsche-only parts or with the undersized Bosch parts? And, since I would always want the correct-sized o-rings, what the up-charge would be for the 928-specific o-rings?
Old Aug 31, 2005 | 07:13 PM
jpitman2's Avatar
jpitman2
Its the back flushing thats important, esp for the CIS ones, where the pintle needs to be held open mechanically while you do it, which is a bit tricky.
jp 83 Euro S AT 49k
Added - Damn! MISSED post 928.....
Old Aug 31, 2005 | 07:41 PM
Garth S's Avatar
Garth S
I've cleaned and tested for a conical spray pattern by using WD-40, carb cleaner, or gas: Fill a short length of tygon tube on the injector inlet with WD-40 - and connect an air supply regulated to the rails lowest operating pressure ( still works well as low as 15psi too).
With a spare injector plug, connect to a fused 12v source with a momentary contact switch. When connected and powered, tap and release the switch - in a spark free , ventilated area.
If the injector is OK, a perfect conical spray pattern will be noted. If not, go to the carb cleaner, and reverse the tubing to the orifice end for a back flush.
Fancy? - no ... works? - yes .... especially if living in the hinterland where injectors are sold at full retail, and cleaning off the vehicle does not exist.
( Motorvac style injector cleaning when installed is a reasonable option).
Old Aug 31, 2005 | 10:38 PM
jyoon's Avatar
jyoon
dave:
when i got my injectors back from injector services/witchhunter, the o-ring appeared a slight bit larger than the o-rings i purchased from 928 specialists. they do not include the larger o-ring on the body. i would just order all of them from a porsche parts dealer, i don't think they were that expensive.
Old Sep 2, 2005 | 12:09 AM
DFWX's Avatar
DFWX
Who would you suggest to have the injector flow checked and balanced? Thanks
