1994 gts electrical gremlin
Last year I bought a 19994gts in Japan. I still live in Japan. I have an electrical problem I need some assistance with. When I turn my interior lights on, they stay on. Even when the doors are closed. I checked the amp differences when I shut the doors or the hatch and the amp difference indicates that the door switches and hatch switches are working. I even changed the door switches and unplugged the hatch switch. The windows operate all the time now. Even with the key switch off. Is there a delay switch somewhere that may be affecting both my windows and my interior lights. The interior lights used to go off after a period of time and a I remember the windows used to not work after I turned the iginition key off. Do you have any suggestions?
thanks in advance.
thanks in advance.
Under the Lift
The light delays are controlled by light combination relay. You can get a used good one from 928 International for half the price of new.
I should add that I believe the window delays are also controlled by this lamp relay. It includes what is known as the X-buss relay, that provides power to certain accessories after teh ignition is switched off. The windows are supposed to operate until you open the doors. That's why I suspect this relay.
isogashii,
Interior lights could be door/hatch switches, however windows functioning with car switched off would be independent of these switches (at least on my S4). Might this be a bad ignition switch???
Sorry I have no help with your gremlin, but lets see some pics of your GTS.
Does your GTS have the special JAPAN fender flares?
Best of luck,
Mike
Best of luck,
Mike
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
