928 Forum 1978-1995
Sponsored by: 928 Specialists
84 Brakes to a 79
Old 08-17-2005, 12:44 PM
Mario H
8th Gear
Mario H's Avatar
Default 84 Brakes to a 79
Greetings all, could someone tell me if the front brake calipers and rotors from a 84 928 will fit onto my 79 928? I have a chance to pick up a set from a junk yard at a pretty reasonable price.
Thanks, Mario
Old 08-17-2005, 12:49 PM
sublimate
Gluteus Maximus
sublimate's Avatar
You would have to replace your spindles too. A better option would be to go with the much better S4/GT or even GTS brakes - they're compatable with your spindles.
Old 08-17-2005, 01:28 PM
GlenL
GlenL's Avatar
You need adapters to run the S4 or later brakes. The S brakes require the S spindles.
The early brakes are on the weak side. The S brakes are a nice improvement and are more than adequate for the car. The later brakes are larger and are multi-piston. You might look at the $ for each option.
Old 08-18-2005, 12:28 PM
Mario H
8th Gear
Mario H's Avatar
Thank you for the replys. I will plan on searching for some S4 brakes. Could you tell me what type of adapters I would need and where I could locate a set?
Thanks again,
Mario.
Old 08-18-2005, 01:01 PM
Mark
Mark's Avatar
Thanks again,
Mario.
ANY of the Big 3 should be able to hook you up! DR @ 928 Specialists was VERY helpful when I did mine.
Old 08-18-2005, 01:17 PM
sublimate
Gluteus Maximus
sublimate's Avatar
Thanks again,
Mario.
Adapters:
https://www.928gt.com/ps-657-130-big...77-860998.aspx
Are you doing both the front and rear?
Old 08-18-2005, 06:23 PM
Mario H
8th Gear
Mario H's Avatar
Only plan on doing the front at this time (depending on cost).
Thanks for the input.
Mario
Old 08-18-2005, 06:42 PM
karl ruiter
karl ruiter's Avatar
I have all the parts to update my '79 to S style and hope I will soon have the time to get this done. My '82 has the S style brakes and I really like them a lot comprared to my '79. I think this is a good way to go...even if you factor in the cost of spindels and an alignment I think you are in at a much much better price compared to the S4 update. Can you get the spindels from the junk yard also?
Old 11-10-2005, 05:45 PM
heinrich
928 Collector
heinrich's Avatar
I'm going to put spare S4 brakes I have onto my '86 and put the '86 brakes onto the '80 ... spindles, calipers, pads swapped. Do I need anything more? Will I be able to just swap? Someone said 993 discs, is that true?
Quick Reply: 84 Brakes to a 79
