928 Forum 1978-1995
Sponsored by: 928 Specialists
Soundproofing question
Old Nov 14, 2005 | 10:50 PM
  #31
FlyingDog's Avatar
FlyingDog
Brendan, how big is a roll?
Old Nov 15, 2005 | 10:55 AM
  #32
hans14914's Avatar
hans14914
Here is Rick's Website: http://www.raammat.com/ Tell rick that Hans sent you.
I will post pics when i am done, but got a bug up my a** and decided to mat the entire car, including the roof pannel, so it may next week till i have pics. Right now i have all the seats pulled, and the rear internal quarters pullled, all the carpet, and door pannels, but i still need to pull out the dash and the head liner to get the internal firewall and roof.
THIS IS IMPORTANT FOR LAYING MAT make sure you de-grease the pannels before you lay the mat on, or will come off over time and make a big mess. Use either the 3M prep you can get at your local paint shop, paint thinner, toluene, mineral spirits... whatver. If your interior is really dirty, clean it with dish soap and water first, let it dry, then go over it with the solvent. Also, it helps adhesion and adds a form fitting look if you use a heatgun on low or a hairdryer on high when applying mat.
If anyone has any questions, feel free to post them or pm me, and i will get back to you.
Hans
Old Nov 15, 2005 | 01:58 PM
  #33
BC's Avatar
BC
One Roll did on coat of the roof, and the rear ofthe car up to the bottom of the rear seats.
Old Nov 15, 2005 | 02:16 PM
  #34
Robert_H's Avatar
Robert_H
Hans,
I am currently in the process of cleaning off all of the old adhesive residue that was underneath the carpeting. I have the area behind the front seats almost done and am working on the roof as well.
What I am interested in doing is to lay down as much sound-deadening material as I can all over the interior and then cover that with a Perlon type of carpeting. I am going for the RS "look" in my 928 and am wondering what material (sound-deadening) would be best to use when it will be covered by carpeting? Is there any that offer a better surface for carpet adhesive? Again, it will also be used on the roof, so it needs to hold.
Thank you for any information that you can give me.
Rob
Old Nov 15, 2005 | 04:17 PM
  #35
hans14914's Avatar
hans14914
Interesting question. Are you carpeting the head liner? Most of the 928 body pannels are held in with fasteners, so its not really a problem. If you were going to have to glue something down, and were really worried, i would probably use a liquid, and spray it on, like cascade. Dont get the stuff in spray cans, as it can really stink up your car. Just get the gallon of liquid and spray it on with a cheapo sprayer from harbor freight. Do you have a link to the carpet?
Hans
Old Nov 15, 2005 | 10:23 PM
  #36
cambria's Avatar
cambria
I bought a 944 a couple of years ago that had the drivers door replaced with a new factory door. The body shop neglected to put in the sound proofing and the door sounded like a tin can. I bought Wurth sound deedening material and applied it to the backside of the door panel and now it sounds like a Porsche door closing.
