I think I need a fan clutch
I pulled the fan assembly out of my 84 to clean and refill with silicone fluid. I got the thing cleaned up and what do I find on the back of the pully where the nut is suppsoed to be? A big glob of welded metal. I am guessing that somewhere along the line the end of the threaded shaft snapped off or was stripped beyond use. I am guessing it was broken off as the welded area only stands about 1/4 in off the back of the pully, so I know there is no nut under the weld. The front of the fan clutch looks like new after cleaning. Should I try to refill and install it as is or should I source another clutch and install it. I have not tried to grind off the weld yet so I am not sure if the pully will be usable once I get it apart. My digital camera doesn't do close up pics to well but I think you can see what I mean. Anyone got a used fan clutch they can part with?
Good question.... you could run a belt straight to the air pump, I think. Anyway, unless you're sure that your viscous unit is bad... be sure you don't store it flat... or the fluid will leak out and it WILL be bad regardless...
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
