Wheel Well covers
Well the tube leads to the Alternator shroud from the front driver side fender ahead of the wheel. In there it attaches to the front (small) splash shield (on the back) with a double C clip or a "W" clip if you like. Probably whatever got caught up in your hose to shred it also ripped up your splash shield.
See my earlier post on a way to get the hose off the back of the splash shield and more firmly mounted.
Your splash shield should have fasteners around top bottom & partially up the sides.
Alan
Alan
Originally Posted by GeaBaldyVx
OK my cooling tube is all FUBAR.. it looks like a weed eater was let loose and was actually draggint he other day.. so I cut it and drove home.. So my question is where in the heck does this Tube lead to? is their an outlet like one on the end of the Intake up top that I am missing or does it simply pour air towards the radiator with a rough edge? As a side note my splash sheild looks a bit battered and abused but, is is supposed to be attached only on one side or am I missing some bolts that hold it up on the opposite side?
Alan, Have exactly the same idea re mounting the cooling tube and air sensor! The splash shield mounting is just wrong and bound to end in tears, as well as tears.....dont thinK my 83 has the same fender brace, but I will make up something if I have to. My old tube was all frayed and dragging string on the the ground - found some 57mm black rubberised stuff for ~ $A10/mt. My wrench uses aircraft quality double skinned tube on 911s at $A75/18" !!!
jp 83 Euro S AT 50k
jp 83 Euro S AT 50k
The alternator must be pretty tough, mine has been without ducting since I bought the car nearly 50k miles ago (driven all weather in the UK). I know I need to replace the ducting, it's on my list of jobs...
Is that what that hose is for?
Mine was dragging when I brought it home and I pulled it out.
Really nice pix by the way.
This forum is awesome. I can't imagine getting so many things done on my new shark without it.
Dave:
Glad I'm not the only one with nasty gouges on those brackets.
Dave:
