Newbie Update & Questions
Originally Posted by jserio
If you have the slotted wheels you should get them chromed. They look much better chromed. If your speedo is not working you could try checking out the sensor in the spare tire well. It connects to the rear top of the tranny. If you manage to get the speedo working and your odo doesnt work that is because that little plastic gear strips inside the speedo. You will come across a consol for much less. Just watch ebay. They was a nice interior that for 500 i think not long ago. And as far as the radar goes any help is good help. GL
I've redone the sensor connector in the spare tire well. I'm going to jack it up and see if the sensor in the trans is even sending pulses. I took apart the odo this weekend expecting to see a dead gear; it looks like someone did a good job replacing it already.
The temp gauge is another oddity. I've replaced the temp sender because the old one was always near zero resistance. The gauge now works sometimes, so I'm guessing it's some wiring issue.
I've done the whole ground cleaning thing at all 6 ground points.
Thanks for the reply!
Originally Posted by deimos
I got a quote for $250/wheel to get them chromed, that seems overly expensive for a dip.
