928 Forum 1978-1995
Sponsored by: 928 Specialists
GTS mirror question
Old Jun 29, 2005 | 02:52 PM
Tony's Avatar
Tony
Default GTS mirror question
Do the 3 screws that mount the motor assmebley to the black metal frame work go all the way in flush, or do they sit proud of the motor assembly by a MM or 2?
Mine seem to bottom out leaving about a 1mmm gap? Just curious.
TIA
Old Jun 29, 2005 | 03:16 PM
Alan's Avatar
Alan
Electron Wrangler
Tony,
Is the motor housing still loose? I was into mine a few weeks ago and they tightened all the way up - not sure where the heads lie when all done - I thought they were below the surface level - but not sure.
Post a picture of what yours look like and I'll probably recall if mine were any different..
Alan
Old Jun 29, 2005 | 03:32 PM
AO's Avatar
AO
Supercharged
Awesom Tony! You're gonna love these mirrors!
I screwed mine home. The head of the screw might sit slighly proud, but the motor assmly, should be tight. Make sure you take a good look at how the mirros locks into the motor assembly. It's a bit tricky to see if it's fully engaged. You don't want that mirror falling out!
How'd the paint turn out? Did you do it yourself?
Old Jun 30, 2005 | 05:29 AM
slate blue's Avatar
slate blue
Tony, have you got the mirrors working successfully? I hear the S4 is much easier than the early cars like mine. I will post some pics of the conversion kit when the photos are developed. Damn that developing
Old Jun 30, 2005 | 01:24 PM
Dave H.'s Avatar
Dave H.
From: Seattle - it's not Hell, but you can see it from here!
mine went all the way down.
hurry up tony, get 'em on...
