Chassis Lubrication
Chassis Lubrication
Lots of squeaking when I turn the wheel and some when I go over bumps. I assume the latter may be springs/shocks? The former I am guessing means there is perhaps some greasing can be done. Is there any "How To Lube Your Chassis" info available for the 928 or should I just grab so grease and go for it.
Thanks.
Thanks.
Nowhere to apply grease that I know of - no nipples. Some apply lube to roll bar bushes - rubber grease? Sounds like something has worn out its rubber bushings?
jp 83 Euro S AT 49k
jp 83 Euro S AT 49k
