928 opening (unlocking door) procedures
Rear hatch
Ok so that's the doors, is there any way to open the rear hatch without using the key, btw my 928 doesn't have a cabin release for the hatch so that obvious answer won't help. The hatch lock is seized but I can access the rear of the car through the front doors so I am not trying to steal it by going in through the hatch ;-) There must be a way to spring the hatch open so I can then go to work on fixing the lock.
Steve
Steve
Apoc - you bring up an interesting point. Putting myself in your position, I'm not sure what I would do. I have an '82 so no cabin release either. I was kindof suprised when I figured out that I had to turn the engine off to open the hatch.
I would say your best bet would be to fix the lock where it is... then open the hatch. That is if you are planning to keep/fix this seized lock. If not... you could probably disassemble/drill the lock from the outside and turn it with a screwdriver to open the hatch... but then you have to keep using the screwdriver until you get a new lock.
Unfortunately, the bolts holding in both the active half and passive half of the latch can only be accessed with the hatch open, so non-destructively disassembling the mechanism while closed isn't really an option. The passive half is in the car... active half on the hatch (you could also figure this out by the key being in the hatch door instead of the rear of the car). The passive half is essentially a square cup, with a little spring-loaded plunger in the bottom that has nothing to do with the actual latch. (I'm sure you've seen this spring behind the rear panel in the trunk compartment.) It just makes the door pop up when the latch is released so it doesn't immediately re-latch. The active half consists of a rectangular plunger that fits into the rectangular cup of the passive half. On the face of the plunger facing the front of the car is a triangular spring-loaded piece that clips under a ledge in the front of the passive half. FINALLY some good news! That little triangle piece is facing the front of the car... so it is facing YOU in the luggage compartment.
It looks like *theoretically* you might be able to slide a very thin, inch-wide strip of metal (like a slim jim maybe? never used one) into the mechanism from the inside. The metal strip would have to turn down as it enters to follow the front face of the plunger to the spring-loaded latch. Now, because of the angle of the top face of that latch and of how strong the spring is holding that latch in the closed position, I doubt your strip of metal would be able to push it in, but in your position, I would give it a shot before I did anything destructive. Be sure the edge of the strip of metal being inserted is free of burrs, and maybe even put a drip of oil on it.
1 Post
Steve
Steve
1. remove tool cover - expose center brace and mecanism.
2. relieve the presure of spring loaded bottom part from the right just above electric motor.
3. insert flat driver in small slot at the top of center brace
- you will see white plastic there, this is the upper part of the lock - you need to push that part at the same time you relieve the presure from bottom part.
4. voilà!!
Anyway it worked for me and I don't see anyother way to open that thing once my lock was broken. The kee to my succes was relieving the presure from spring loaded mecanism...
When I locked my keys in the trunk of my S4 I called out an auto locksmith (who happened to own an older 911). I had found the info at the top of this thread and printed it for him. An hour later he still couldn't get in, and ended up using a small hand pumped airbag and a wedge to lift the side of the hatch and hook my keys out.
I'm not convinced the method works on all cars as a result.
Ian
Ian
Hello
Thanks for this manual to open an 928. Now im sure, I`ll visit the U.S.A and try to find one of this wonderfull cars. If this tool really works I`ll post it here. ( In good old Germany we use the Key of the car to open and start it. Because we did not know how to open the door without key???)
How did no nobody delete this "helpfull" thread for an car thief? To help with such an Information via Mail, maybe we can do. But to post such informations inside an www board will be a little crazy??
Best regards from Germany ( the land where grows Porsche and honey )
*Schocki warst Du das? hehehehe
