Continental ContiSports
While I'm glad there's been some discussion about tyre brands, no one has commented on the ease with which I managed to wear a flat spot on the fronts when I locked the wheels. Has anyone else trashed a pair so easily?
If you watched the European GP, you saw that even one of the best drivers with the most advanced tires and car can flat spot it, and the dramatic results that eventuated.
Heinrich, it seems that no hardness of compound would keep someone from flat-spotting. (?)
Originally Posted by heinrich
Chris, harder tyres rub off less easily. Try to flat-spot your rubber mallet, versus flat-spotting an eraser .....
928 Collector
Here's the whole discussion:
Short form:
Originally Posted by KID
................... the ease with which I managed to wear a flat spot on the fronts when I locked the wheels. Has anyone else trashed a pair so easily?
Originally Posted by Heinrich
... any tyre will do that except the ones that are so hard you wouldn't want them anyway....
I flatspotted too easily
Would have happened that easily on any tyre except very hard ones which would flatspot less easily
928 Collector
Hard tyres slip easily. Their compound is tougher also. Therefore they don't rub off as easily, you just slide around on them. Soft tyres make their grip by giving the road surface a little of themselves at every brake, acceleration or direction change.
What I would like to know is who shaves tires down to re round them. I know it used to be quite popular to shave tires for some types of racing, and now that many cars have two sizes of tire you can't rotate for even wear.
