928 Forum 1978-1995
Sponsored by: 928 Specialists
HVAC Control Unit/Instrument Cluster - Replacement Bulb/LEDs?
Old Jun 17, 2005 | 01:18 PM
Randy V's Avatar
Randy V
25 Year Member
Jen does bring up a good point. If I install LEDs in place of the standard bulbs in the pod, is there any way to know I have them in the correct way without having to hook up the power connectors?
Any visual references on the bulbs, Chuck?
Old Jun 17, 2005 | 02:15 PM
Chuck Schreiber's Avatar
Chuck Schreiber
Randy,
Just hook up your wiring harness to the instrument housing whie testing. That's the probably the easiest way to do it. I put a big folded towel over the steering shaft so when I moved the instr. housing around it would not get damaged. Make sure to disconnect your neg. cable while you're messing around with the housing as well. I know you already know this but some folks may not remember. Better safe than sorry.
Check all connections and proper polarity. I'm sure if you end up pulling the trigger on the Jager Kit as well, Paul's got the std.op procedure there. He's pretty thourough.
Old Jun 17, 2005 | 08:34 PM
Randy V's Avatar
Randy V
25 Year Member
Thanks, Chuck.
The Jager kit is a good upgrade for the older cars, but it seems the S4/GT/GTS models have pretty good instrument illumination.
Old Jun 18, 2005 | 01:37 AM
Chuck Schreiber
The GTS is a good start for most, but man, Jager has some cool shee-hot!!!!!!!!
http://www.jageng.com/928LED.htm
Old Jun 27, 2005 | 08:09 PM
Randy V's Avatar
Randy V
25 Year Member
In the picture on page one of this thread:
https://rennlist.com/forums/showpost...24&postcount=6
Are the 'yellow' base bulbs the same type/size as the 'blue' base bulbs?
Old Jun 27, 2005 | 08:48 PM
ROG100's Avatar
ROG100
Basic Sponsor
Hi Randy,
Back from vacation so in a better position to help out.
See PET below.
16 off 928 641 982 04 are the blue backed bulbs
10 off 928 641 982 03 are the yellow backed bulbs (clear)
4 off 928 641 982 02 are the yellow backed bulbs (red )
4 off 928 641 982 01 are the black backed main illumination bulbs.
Hope this helps.
Best,
Roger
Old Jun 27, 2005 | 09:01 PM
Randy V's Avatar
Randy V
25 Year Member
Thanks, Rog.
So the yellow base type come in clear and red? Do you know what the separate colours are used for - i.e., which indicators slots use red and which ones use white?
Old Jun 27, 2005 | 09:13 PM
ROG100's Avatar
ROG100
Basic Sponsor
Randy,
When you look in the back of the pod it is very clear.
We are talking about the LCD lights for the computer read out.
There are 8 at the bottom of the pod as per the picture I sent.
4 are clear with yellow bases and 4 are red with yellow bases.
Roger
Old Jun 27, 2005 | 09:18 PM
Randy V's Avatar
Randy V
25 Year Member
Yeah, I'm just tryin' to figure out which ones I need - at $8 a pop, I only want to order as many as I really need. I want to order them before I remove the pod, so they're on hand to pop 'em in.
So I suppose the red coloured ones are for the LED display, and the white coloured ones are for the gear selector display.
Old Jun 27, 2005 | 09:40 PM
ROG100's Avatar
ROG100
Basic Sponsor
All 8 are LCD.
Blow up the picture and you can read the description.
The four top LCD's are white and the bottom four LCD's are red.
Which of the bulbs are you planning on changing?
It is a crap shoot whichever way you go.
The only ones that are on all the time are the LCD's and the D light.
Once you are in there you will see some discoloration from the D light due to heat build up.
I have yet to see a bulb go out on the digital setup and can't remember anyone posting about it IIRC.
So don't overdo it.
Once you have taken the pod apart it becomes very straight forward to do again on the off chance that you lose a bulb.
Roger
Old Jun 27, 2005 | 10:20 PM
Randy V's Avatar
Randy V
25 Year Member
The 'P' and 'N' lights are out on the gear selector display. And just today, the 'Brake' test light stopped illuminating (one of the blue base bulbs).
Old Jun 27, 2005 | 10:57 PM
ROG100's Avatar
ROG100
Basic Sponsor
Randy,
I will keep my mouth shut in future.
Old Jun 28, 2005 | 01:28 AM
Randy V's Avatar
Randy V
25 Year Member
It wasn't you Rog, but I swear, whenever I start discussing an issue that could go wrong, sonofabitch if it doesn't happen within a few days!
Old Jun 28, 2005 | 01:36 AM
V-Fib's Avatar
V-Fib
We had a choice?
Randy, your new 928 has electrical issues? Is there a 928 in existence with out at least one electrical Gremlin?
Old Jun 28, 2005 | 03:05 PM
Voytek's Avatar
Voytek
Chuck,
S4 Instrument cluster has 3 or 4 larger bulbs, referred to by 928 Intl as 900 631 019 90. Do You know what is OSRAM's equivalent to see if Your source has them?
Wouldn't #74 be too bright for instrument cluster application?
