Here are some preliminary Details on our New Sway Bar System that was unveiled at Sharks in the Mountains this weekend.
928 Specialists Adjustable Performance Sway Bar System
Front and Rear Adjustable Performance Sway Bars for your 928!
Cold Formed from prehardened bar stock to prevent heat treat deformation and to retain Sway Bar "Memory".
Front 28mm Solid Sway Bar - 150% Stiffer than Factory Bar @ Stock Link Position - 3 Way Adjustable Drop Link Locations (Stock Location, Stiffer and Even Stiffer).
Rear 22mm Solid Sway Bar - 187% Stiffer than Factory Bar @ Stock Link Position - 3 Way Adjustable Drop Link Locations (Stock Location, one Stiffer and one Softer).
Our Design allows you to use Factory Original Bushings, Drop Links and Hardware, if desired (not recommended on "stiffer" link positions).
Increased Front Tire Clearance, our new Front Bar gives you more Wheel/Tire clearance than the stock bar. You can safely run a front 265/30-19 with 9.5" wide 72mm offset wheel or larger without any Sway Bar rub!
Our Sway Bar kits Include Heavy Duty Heim Jointed Pre-load Adjustable Drop Links.
Front Sway Bar Includes New Heavy Duty Mounting Bushings and Brackets (stock Brackets/Bushings are used on rear)
Both of our New Sway Bars come with Mount Bushing Locating Collars to eliminate Sway Bar Shift.
Please note : Pricing is for Introductory Special Pre-Orders Only. We expect to be shipping these in approx. 6 weeks.
Complete Front and Rear Set as pictured with all Hardware - $399!
Front or Rear Set only with all Hardware - $225 each
Special "BAR ONLY" Pricing for 928ers that have purchased our Ott Adjustable Drop Links (you can use your existing Drop Link Hardware) , $150 per Sway bar!!
928 Specialists Performance Sway Bars are Custom made for us by ADDCO Manufacturing.
ADDCO has been manufacturers of Quality Sway Bars and Suspension Components for over 40 Years!
First company to incorporate polymers into stabilizer bar bushings!
First and only manufacturer to develop "cold forming" of prehardened bar stock to prevent heat treat deformation and to retain material specifications in extreme use
First and only manufacturer with the capability to produce both solid and tubular bars, top diameter os 2 1/8" and 3" respectively
First to develop and patent an "in-cab" disconnecting anti-sway bar system.
Please visit our website over the next few days as I add more details.
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor www.928gt.com
If any one needs hardware kits I have some in storage at my property in NC. It will be this fall before I go back there but I found boxes of new front and rear hardware and can bring some back if needed. I found all kinds of 928 goodies I had forgotten I still had, including a complete 91S4 engine!
Cheers,
Dave
Hold on to a set of front hardware, please. I have your front sway bar. :-)
