No idle after a timing belt check
I check my timing belt tension warning wire today and after reinstalling everything, the car has no idle. It seems running on less than 8 cylinders because I can smell gas when I rev the engine.
I removed the distributor (and clean it) but did not turn the engine at all.
Is it something special to do when putting it back ??
1987 S4
Sounds like an ignition problem.
Make sure all the wires are well connected to the distributor(s). If you don't find anything, use a timing light to check for spark on each wire.
928 Engine Re-Re-Rebuild Specialist
Check your coil wires. If those are connected, make sure you don't have any of the spark plug wires in the wrong position on the distributors. I experienced exactly what you're describing when I had two wires swapped on the distributor.
I know that the set up of an '87 s4 is different than a two valve '79, but I'll fire one off just in case this may apply. Check the ignition rotor rotor position at TDC. Also ensure that rotor is completely seated. When removing the distributer this can be an issue.
If all was well before you started to work on the car reverse engineer how you put things put back together. As has been mentioned check the rotor is fully seated and in correct position, all ignition wires are fully seated and in correct position including the coil wire.
It is true that the coil wire position is not at a easy position. I did replace it yesterday. I try again this afternoon.
I will check the rotor too.
I removed the air box and restarted. About 10-15 seconds of rough idle (+ that sound from or the MAF) then everything became normal again.
I did not re-check the ignition or wire at all !!!
Porsche probably use Microsoft software - reboot and it will work
![typing](https://rennlist.com/forums/graemlins/yltype.gif)
What is the fonction of the Mass Airflow?
