Water pump on the fritz, question about driving
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Hey guys, recently the water pump on the 928 has decided to start leaking. It's definitely time for a replacement. However, it's not noisy enough to the point of notice. The coolant leakage is from the front of the engine. It recently started leaking this past Saturday after I drove it home from my final exam. It was smoking under the hood. When I popped the hood I could see smoke and a 'burnt sugar' smell coming from the front of the motor. The temperature on the car was well below the red. However, it's strange how the water pump bearing isn't noisy after a failure. The belt tension light didn't even go off! I'm taking it in next week to get the pump replaced and am wondering if I should drive it there. We started it this weekend to move it and to check for more leaks. It didn't leak, but the coolant reservoir volume we took notice to since it was full; it's now 1/3 of the full line mark. ![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Should I tow it next week or fill it up with coolant and drive it the 12 miles to my buddy's shop?
Do You feel lucky ? If the pump fails completely it is $4,000-$7,000 to pay to have the valves fixed. So do you pay for a tow $100 or make a run for it ? to be an even money bet the pump only need fail about one time in 60.
Fuse 24 Assassin
Fuse 24 Assassin
ok this baby sits until next wednesday when the tow guy picks it up. I don't feel like throwing another 5 grand into it after that.
![nono](https://rennlist.com/forums/graemlins/nono.gif)
I think my pump failed completely, red light, smoke, whole shebang. I've already confirmed the block is okay and all. What else should I look for to to see if I didn't avoid this valve damage?
By the way Tom, Andy, as long as you have those avatars, neither of you can post unless the other one responds immediately
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
928 Engine Re-Re-Rebuild Specialist
I agree you shouldn't drive it.
However, mine leaked for nearly a year before I replaced the pump. All the time I thought it was a thermostat housing seal.
Remember the belt tension light tells you just that...The tension on the belt. Thats it.
Your belt could be tensioned perfectly but if the water pump siezed up, you will be dragging a perfectly good, healthy, well tensioned belt over the siezed water pump pulley. It will wont last long.
Fuse 24 Assassin
Fuse 24 Assassin
I don't get as to why the light didn't come on still. Maybe because the bearing has not seized or thrown out of alignment into a lot of play?
Fleet of Foot
The bushing, if it is in fact your water pump, is just leaking. It apparently has not degraded to the point where there is enough play in it to slacken the timing belt. If the water pump is leaking the coolant is most likely dripping out of the weep hole off the water pump pulley shaft.
928 Collector
They're often bypassed (grounded out) ... but the warning system is not for your pump it's for the belt. So, a dead pump may grind peacefully into the engine block, eating aay at the water passage, and when that stock is all eaten away, it may finally seize ... or it may wobble enough to loosen the belt. OR .... in my case, the "specialist autohaus brainiacs" had overtensioned her ALL THE WAY ... no warning there.
The light hasnt come on because your bad water pump has nothing to do with belt tension. You could have a solid piece of steel in place of the smooth running water pump pulley. Your belt tension would still be fine but the belt would go up in smoke in a matter of minutes....which is what you setting yourself up for. Also, remember the clearance on the impeller and the block isnt much either.
Fleet of Foot
Shameful Thread Killer
There is a weep hole in the bottom of the pump casting for this very reason. When the shaft seal failes, fluid goes by the seal lip, down the inside of the pump housing, and out the weep hole. Now, this hole is pretty small, and is only intended to sacrifice a small amount of water/coolant and protect the front bearing.
You would probably be fine taking 12 miles, but it's a chance. There's no reason to add coolant, just add plain old water. The risk as stated is if the bearing siezes, it takes out a lot of innocent but costly valves with it. I would tow or trailer it until it's fixed, but you could take the chance.
Doc
Doc
