WE HAVE IGNITION!!!!!!!
928 Engine Re-Re-Rebuild Specialist
After farting around trying to figure out why I wasn't getting spark, Andrew found a wire under the fuse panel that wasn't plugged in...plugged it...turned the key...
IT'S ALIVE!!!!
I'M ****IN GOIN TO SITM!!!!!
IT'S ALIVE!!!!
Here's the videos. First one is before we figured out that there was a wire under the fuse panel covered that was unplugged.
Second one is from 2 hours later, after I'd started thinking something was terribly wrong. I sound like a moron, but it's been NINE MONTHS since I last heard my car run.
No drive around the block tonight. We didn't hook up the radiator hoses or any of the belts. That's next....after I get a new radiator drain plug (cracked it when I tightened it tonight
If the files don't stream fast enough, just *right click* and *save as*
http://www.928oc.org/928oc_michigan/fireup1.avi
http://www.928oc.org/928oc_michigan/fireup2.avi
)If the files don't stream fast enough, just *right click* and *save as*
Originally Posted by Randy V
What is the function of the wire that caused the problem?
I'm not sure yet, but it branches off from the O2 sensor wire.
