What size tire on a 17"x10" rim?
Range Master
Pepsie Lite
Pepsie Lite
Originally Posted by hinchcliffe
Any chance I'll have to roll my fenders? ot sure what the offset is.
Take a straight edge and put it across the back of the wheel. Measure the distance from the straight edge to the mounting surface, which is the backspace. Now measure the entire width of the wheel and divide that number by 2. Subtract that number from the first number and you have the offset.
Example:
Width of entire wheel=250mm
Backspace= 175mm
1/2 X width = 125mm
175mm - 125mm = 50mm
Example:
Backspace= 175mm
1/2 X width = 125mm
Range Master
Pepsie Lite
Pepsie Lite
47 works for me and up to 65 with a 17mm spacer has also worked ok for me.
11" rim uses 63.5mm offset for a perfect 928 fit. (8 1/8" backspacing) on a 10" rim, you wan that back spacing to be 7". To keep the same closesness to the fender. any less backspacing will bring the tire toward the chassis.
as was said, 295 fits well, as well as if you can find one, a 305. 315s are too tight on the 10" rim
mk
mk
Should I be trying to get back to the original aspect ratio? 245-45r16 that would make a 516.65mm tall tire. So a 285-30r17=517.3 (Not Made) or a 275-30r17=514.3 (Not Made) Or try a 285-40r17=545.8 or 275-40r17=541.8. How much woul the speed-o be off by?
http://gs.tolan-hoechst.com/tirecalc.htm
Answers to all your wheel fitment comparrison questions can be found here.
keeper
