Big Brakes For Sale
Sorry, that might have been a little confusing. If a GTS is the same as a 993 TT, then the GTS REAR calipers are the same size as 993 (NA, not TT) FRONTS. The front brakes are larger, but not by very much.
Found this: Porsche 944 Turbo S bromsok sitter mer på vilka porschar...? << Föreg. ämne | Nästa ämne >>
Tack pöjkar! Mycket nyttig och bra info! =))) Mina kolvar är mycket riktigt 36 o 44'a... Några nummer på oken hittar jag inte direkt. Förutom de nummer på halvorna av oken då... 20.4565.00 samt 20.4564.00. Sen står det 88 på båda halvorna och en liten 2'a i närheten av 88.
Man misstänker ju lite lätt att 88 är året...
Ska ringa mekonomen nu och kolla vad de säger. Men all info jag fått av er ska jag nog kunna hitta något! Återkommer hur det går för mig.
In spanish please
Originally Posted by SharkSkin
My understanding was that all 86.5+ 928s used the same rear caliper...
Where would the part numbers be located? I don't see any numbers other than the ones I posted earlier. Without measuring, they appear to be about the same size as the brakes on my '87S4.
Steve,
I really don't know about the part numbers. They ARE the same size as your S4 brakes. Sorry if I confused anyone; I'm just trying to help out. What I am trying to say is that you said you think they are the same size as GTS calipers when they are not. They are the same size as S4 front calipers. Just trying to help out...
Steve,
Sorry don't have Swedish text on my keyboard.
