Oil on 1 Plug
Oil on 1 Plug
Hi All,
Changed my plugs today and noticed that one of them had some oil on it. Is this usually caused by a valve-cover gasket that is leaking, or could it be something more serious?
TIA!
TIA!
Yes, there is a seal on the valve cover for each plug hole. Put a rag down the hole and clean all the oil residue out, then check again in a couple of weeks ... unless really bad I wouldn't go in there for just one plug hole seal.
Just add to yout todo list sometime.
Chris
Chris
