LED key Light
1 Post
it's amazing that Andrew has so much energy and time to check up on John. When we, as more than one physical being have had a chance to read all the posts by a select few, it's funny. Either we see a hint of sarcasm, or Andrew has a crush on John.
Since Andrew spends so much time, we are really thinking he has a crush. No thats weird.
Sorry Jim, as Big Dave say's this thread has taken on a new bizarre direction.
At the risk of putting this thread back on topic :-) the LED conversion can be done without grinding:
http://www.arnnworx.com/PorscheWebPa..._light_fix.htm
It uses smaller #389 batteries.
-Joel.
-Joel.
Electron Wrangler
Jim/Joel,
Done! and it really works well - I used Joels linked instructions which made this slightly easier. It took me < 3mins (yes really just seconds) to do this. It took me more time to find the batteries & LED's in Radio Shack than to install it all. It all fits in great and its way way brighter than the original, likely it has a much longer run time - although I think this is one of those applications where the batteries die from old age not usage.
Alan
Alan
This was the first thing I fixed when I got my shark! Your version looks better engineered than mine though. A 3V Li battery slips right in and a little fancy wire bending and you have a nice bright light.
This is basically a variation of what Jim showed, however instead of a spring I use a little piece of foam on the top with a notch cut in it. The foam against the button gives the cushion, and the button moves the LED lead to contact the battery.
Here are the basic parts:
Step 1: trim the LED leads and bend them until they are "just right"
Step 2: drop in the batteries (LEDs care which way you do this)
Step 3: Put in the little foam insert
Step 4: Assemble and test
Under the Lift
Marc:
Careful where you point that! It's blinding.
I'm a little confused about the batteries. Lithium buttons are usually 3 volts. Silver oxide 1.5. So, do the LEDs have a range of operation so that 3 (2 silver oxides) to 6 (2 lithiums) volts is OK? How about 1 lithium and a spacer.
