HVAC Problems
What shall I look for?
The car has no vacuum leaks whatsoever... Am I missing a component within the HVAC?
Thanks in advance,
Alex
1990 928 GT
1984 928 S2 Manual (GTS Gearbox and Manual PSD)
Check out this site (thanks to John Pirtle) for more information:
http://members.rennlist.com/pirtle/svc_act.html
BTW, the engine came out 2.5K miles ago and underwent a total rebuilt - the only original parts left are the pistons, crank, block and heads... Everything else is NEW, including all vcacuum lines, hoses etc...
I'm going through the same job right now on my 90GT, and although I thought all the lines were okay, you can't test them without disassembly of the center console to expose the vacuum manifold. There is a supply line that goes through the firewall and gets it's vacuum from a small line right near the top left of the firewall. There is a tee fitting that provides vac to the flappy solenoid, and the other line leads to the center console.
This line that feeds into the console goes to the manifold. With all the manifold electric solenoids normally closed, it's hard to troubleshoot the vacuum problems. Once exposed by taking off the console, you are able to test the multi-colored lines individually to test the vacuum diaphrams which develop pin-hole leaks in them. My car had 4 out of five defective, including the infamous AC recirculating diaphram located under the AC/heater blowerin the right front well just below the windshield.
The Pirtle write up is invaluable in finding and fixing the HVAC systems. Your symptoms show all the signs of failing vacuum diaphrams. I will be posting a write-up of R&R of the AC recirc diaphram once I'm finished. I also discovered a way to replace the comb-flap control diaphram WITHOUT REMOVING THE DASH, POD, AND AIRBAG!
Also, unless you have recently exchanged the heater control valve, it will need to be replaced($12 USD). The vacuum diaphram tends to leak, and the rubber bushing in the valve also deteriorates and even if the vac is working, the bushing swells from hot coolant and fails to seal. Replacing this will improve your AC operation immensly.
Doc 90GT in resto, working HVAC problems,
Remove the cover from the driver's side of the center console.
Look next to the driver's calf and find the bundle of small colored plastic tubes.
Get a few inches of small rubber or soft plastic tubing that is a snug fit on the colored tubes.
Use a sharp razor knife to cut the orange tube. Apply vacuum to the end that runs up into the dash (not the end that runs forward to the solenoid manifold). If the orange tube holds vacuum, splice it back together with the small tubing. If it won't hold vacuum, plug the other end (the end that runs forward to the solenoid manifold) until you get a round tuit and replace the leaking center comb flap actuator.
Repeat on the blue, yellow, green lines.
Do not cut or test the white (heater valve) line or the black (supply) line.
