928 Forum 1978-1995
Sponsored by: 928 Specialists
Calling for engine pictures!!!
Old Apr 19, 2005 | 12:45 PM
Big Dave's Avatar
Big Dave
928 Engine Re-Re-Rebuild Specialist
Default Calling for engine pictures!!!
When I took everything apart, I took some pictures, but it turns out that I didn't get all the angles that I need to make me comfortable that I am putting everything together the right way.
I remember seeing someone had a library of hosted pictures documenting their disassembly and re-assembly process, but I no longer have the link.
SO....I'm officially asking for links to engine assembly pictures. Specifically, I'm looking for pictures of wire routing, vacuum hose routing, and pictures of the sides of the engine so I can confirm that I've got hoses and components attached correctly.
If you're the owner of the pictures, please let me know if you'd be willing to allow me to include them in a future area of my website detailing the assembly process.
Old Apr 19, 2005 | 01:08 PM
Tony's Avatar
Tony
These may help a little. The one from the back is, well, kind worthless
I may have some here somehwere but for now HTH.
Im eventually heading down the same path you are Dave. This engine is now gutted down to the block halves. It will be a daunting task to put it all back together...so pave the way!
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Apr 19, 2005 | 01:54 PM
Lizard928's Avatar
Lizard928
Dave, the vacuum diagrams are on page 98 of volume 1 of the factory manual for your car, as for the wiring all the injector, maf, timing pickup, TPS, are all just sitting on top of the engine, all the rest are run behind the timing belt covers from the alt up to the passenger side camshaft to mate up with the jumper terminal there,
Old Apr 19, 2005 | 02:27 PM
Big Dave's Avatar
Big Dave
Thanks Tony. Those help a little. Yikes!
Old Apr 19, 2005 | 02:45 PM
Big Dave's Avatar
Big Dave
Cool...one puzzle solved....(posting the pic in case anyone else needs it)
File Type: jpg
