Front Cooling Flap Runs Constantly.
In the '87 S4, the cooling flap in front of the radiator opens and closes constantly. The flaps never stop at any point, just open, close, open, close.......
I unplugged it in the 2/3 open position so it won't overheat, but don't know where to go from here.
Has anyone else had this problem and know what could cause the problem? Relay, motor, switch? Not a huge deal, but I would like to fix it soon so I don't have to worry so much about rocks hitting the radiator.
Thanks!
Thanks!
My advice is fix it if you can........I hate to see good systems that just need minor repairs disabled. The flaps do serve a purpose.....more controlled engine warmups, and they actually direct and funnel air more directly into the radiator. Maybe a bit overkill, but if a couple of bucks is all it takes to fix it why not keep them active.
Check/reseat connection to motor. Try a new relay, they are less than 20 bucks. If that doesn't work you might want to find a good used motor.
The relay number is XVIII and p/n is 944.615.119.00
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Originally Posted by deliriousga
Stinkin' POs!
One of them (or most likely their "Porsche specialist" mechanic) put an ignition relay in the XVIII spot. The correct relay has one more prong than the ignition relay. So I guess they thought "it has 4 out of 5 prongs and half of the part number matches so it must be ok." Extremely frustrating, but at least they are working now. It's amazing how well things work when you actually use the right parts! ![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
