Write Up for Changing Cam Sprockets?
Is there I write up somewhere on changing the cam sprockets without having to do the cam timing? I am about to replace my worn cam sprockets and do not want to have to pull the cam covers on my MY85 (concerned about breaking those 2 piece cam cover bolts). I searched on Nichols and here, didn't see anything. I just recieved the cam timing tool folr the 32V from Porken, have to see if that will help with the installation.
Any tips are greatly appreciated.
Glen
Glen
Hi Glen,
i will do the same this weekend and there are some instructions in this thread:
Cam gear change
I have also bought the cam timing tool kit from Porken.
Still not received yet though :-( , it would make the job a lot easier for sure.
Cheers/Peter
Cam gear change
Cheers/Peter
Supercharged
I don't think you have to worry about it as the gears are indexed to the cam by the woodruff key (I think that's what it's called). You will have to check the timing belt alignment however and make sure they are aligned with the crank. I'm sure others will chime in.
Basic Sponsor
Just did mine.
The key allows for a lot of movement so you need to mark its position.
Replace the 5mm (I think) bolts that hold the rotor in place. Measure between the face of one of the flats of the bolt and the leading edge of the slot in which it sits. I did the measurement on two of the bolts for safety.
I was set at TDC when I did it so aligning the new sprocket was straight forward. Just align the V on the gear with the mark on the housing.
Replace the same bolts in the same position and set to the measurement, tighten the main bolt and you are good to go.
This info was given by Marc at Devek, thanks Mark.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
To recapture the same timing, Rog100 has the good answer.
Anyone know of a write up on the crank gear too?
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Inventor
Glenn, Peter,
I am away from my computer all day again this week, but I will add a section to the ZVA manual about changing the gear.
Should be a snap with the tool.
~Get the initial measurement with the indicator at #1 TDC.
~Lock the crank at 45 degrees, as if changing the timing belt.
~Replace the gears and belt, clamping the hub to the gear in the center of the adjustment slot.
~Unlock the crank and set to #1 TDC.
~Follow the adjustment procedure to reset to the initial measurement.
You may need a gear puller to take off an old gear. I suggest using 90W oil to coat the cam and the hub/gear hole, to make it easier to remove and adjust later.
Oops, late again!
Oops, late again!
Basic Sponsor
Here are the detailed notes from Marc.
PS: I was doing a 32V engine.
Use 45degrees if you feel better about it just mark the cam gear to the housing and transfer the mark to the new gear.
to put the cam belt back exactly whre it "was" is simple.
1 Mark belt and sprockets
2 remvoe distributor rotor
3 insert 5mm screws
4 measure distance between screw head and leading face of cam sprocket slot. This locks the sprocket to the spyder
5 Remove old sprocket
6 Mark new sprocket with "belt marks"
7 Install sprocket onto spyder and locate with 5mm screws to the distance measured above in step 4
do other side
Simple!
KEEP in mind, that no two cams are identical. By measuring S4 cams, the lobes to keyway are often off. I have found that by measuring 5 sets of cams, that the slot is off by approximately 3+ degrees against #1 lobe.
That si why we have plus or minus 8 degrees of sprocket adjustment.
Marc
3 insert 5mm screws
do other side
Simple!
Marc
Supercharged
Glen- You obviously see the benefit. Why not pony up for a 2 year membership and keep the dream alive. You know you need to do it.
Edit: I just realized that all of your replies came from PAID members. C'mon and join the ranks.
Originally Posted by Glen McCartney
Thanks everyone, where else can you get this kind of information!!! Makes owning the 928 a piece of cake, gotta love it.
Supercharged
Glad to hear it... I'm sure Randy can help you out.
I am a paid member, membership #030225-2780, EXP. 2/24/2006, don"t know why it doesn't show up as Rennmist member... Randy???
