928 Forum 1978-1995
Sponsored by: 928 Specialists
Jumpy Idle, Running Rough
Old Mar 21, 2005 | 06:21 PM
TLegendGS's Avatar
TLegendGS
Default Jumpy Idle, Running Rough
I have a 87' 5-speed and lately my idles been jump as well as my voltage meter. When running I notice the car slightly jerks back and forth at lower RPMs. The previous battery died so I replaced it with an Interstate MTP-40R and still getting the same problems. I did a few searches and found it might be the alternator, ignition coils, and/or spark plugs. I just had the waterpump and timing belt replaced so Im not going to be able to afford to take it to my mechanic. Any suggestions appreciated.
Old Mar 21, 2005 | 09:19 PM
Daniel Dudley's Avatar
Daniel Dudley
Try some STP gas treatment with a can of fuel injector cleaner and about 5 gallons of gas. Its cheap. Look for vaccume leaks. Wiggle all electrical connectors with the engine running. Look at the inside of the distributor cap. Pray.
Old Mar 29, 2005 | 04:45 PM
TLegendGS's Avatar
TLegendGS
Thanks Ill try that when I get a chance. Strange thing is this doesnt happen everyday. Sometimes the car runs fine and sometimes like crap.
Old Mar 29, 2005 | 05:16 PM
worf928's Avatar
worf928
I would recommend Chevron Techron treatment rather than any of the alternatives for injector and chamber cleaning/conditioning.
Surging could be a lot of things. I further recommend PMing Jim Moorehouse - he can set you up with all the info you need so as to be able to bypass your mechanic and his bills. In particular though the LH/EZK test matrix is the place to start: LH/EZK Test Matrix
Old Mar 29, 2005 | 05:48 PM
Landhai's Avatar
Landhai
For what it's worth, on my 86.5 5spd. I just had the plugs, caps, rotors and wires all replaced and the air/fuel ratio checked and guess what... I've got a jumpy idle and a wiggly voltage (and oil pressure) meter. Oh, and it surges at low RPM too. Previous owner spent about $5k fixing various vacuum leaks, so I'm reluctant to think it's that. I may try to fuel injection cleaner route next too, but any other suggestions appreciated.
