928 Forum 1978-1995
Sponsored by: 928 Specialists
half-throttle
Old Mar 20, 2005 | 06:47 PM
Kevin Michael's Avatar
Kevin Michael
Rocket Pilot
Default half-throttle
Hello all,
A problem just started today with cold-starting. I have to give it half the pedal for it to fire off. Hot starts are fine. Any clue to what it might be?
thanks,
Kevin-n-Laura
Old Mar 20, 2005 | 07:16 PM
Kevin Michael
Rocket Pilot
Bump....... the car in question is in the sig....87 s4-5 sp.
Old Mar 20, 2005 | 09:39 PM
Tony's Avatar
Tony
Id check the idle switch...it may not be closing.
Old Mar 20, 2005 | 09:50 PM
Kevin Michael
Rocket Pilot
thanks Tony.I will get on it tomorrow.
Old Mar 20, 2005 | 09:59 PM
Jim_H's Avatar
Jim_H
Kevin,
I looked for the idle switch here and couldn't find it. Maybe you will have better luck.
http://members.rennlist.com/v1uhoh/underthe.htm
Old Mar 21, 2005 | 03:01 AM
mark kibort's Avatar
mark kibort
idle switch, what the heck doest that have to do with anything? ive been running without mine for two models of 928s both the 84 and the S4. actually, i have mine selectable on my race car. generally, i run it with out it.
sounds like the cold start system is malfunctioning.
MK
Old Mar 21, 2005 | 07:26 PM
Kevin Michael
Rocket Pilot
update! Problem solved. the a.c. was also on the blink and made me suspicious of vacuum leaks. Found the vac tee under b- booster to be unplugged !!!! All is well and thanks, everyone.
Kevin
