Flappy open when boost?
Does the flappy open when the turbo is building up the boost at 4000 rpm and past?
The vaccum is none at that moment....I guess.
I know that I can look under the rubber hat but I havent installed the turbo yet and trying to get all info first.
/Jonas
/Jonas
You will need vacuum for the flappy to open. The ECU signals the flappy solenoid, based on rpm and load, except that with boost you may get a differnt opening point.
