928 Forum 1978-1995
Sponsored by: 928 Specialists
Loose or broken mirror...HELP!!!!
Old Mar 6, 2005 | 09:49 PM
Sierra Shark's Avatar
Sierra Shark
Default Loose or broken mirror...HELP!!!!
The passenger mirror on my 88 S4 is loose?? or broken, not sure which. The mirror housing can be raised about a 1/4 inch straight up and can spin around on the inner post. Can this be tightend? If so, how do you acces the post? Do you have to go through the door panel or can you back out the hex head bold that holds the mounting plate to the car and reach it that way. I have heard that if you back out that hex head to far a nut on the other side will be lost forever. It seems as if the only thing holding the mirror to the car is cable going through the inner shaft. HELP !!!!!!!!!
Old Mar 6, 2005 | 10:00 PM
Big Dave's Avatar
Big Dave
928 Engine Re-Re-Rebuild Specialist
Does this help?
http://members.rennlist.com/bigdave/mirror.html
Old Mar 6, 2005 | 10:01 PM
s928s's Avatar
s928s
It sounds like the pivot mechanism has come loose, tou and remoove the upper part of the mirror to check. YOu need to remove the mirror glass by unlocking the lock ring. remove the 4 8mmscrews that hold the mirror base down. that should expose the mechanism for the adjuster .
Old Mar 6, 2005 | 11:38 PM
Sierra Shark
Big Dave and s928s, thank you both. Sounds like all's not lost. Any suggestions on carefully removing the door panel? Looks like I got a new weekend job. Thanks again, Rennlist to the rescue!
