Looking for a short 2-post lift
#31
Under the Lift
Gretch:
So, you have a standard 8' ceiling too? I see some elevation changes. It looks like you have more height upfont, so the garage door rolls up higher. Nice that you can snuggle two cars in there, especially if the ceiling is 8'.
Am I right in saying one thing nice about the 2-post lift versus a 4-post platform, it appears, is that you can get one car above the other with less of a clearance issue (no platform, just hanging tires). Although, on second thought, the wheels hang a lot lower than on a platform. So, I guess it's a trade off.
I have a big swing-up garage door. I might convert it to roll-up to get it tighter to the ceiling. It would be nice to get the 79 inside.
#32
Gluteus Maximus
Originally Posted by Gretch
Those "pits" were outlawed a couple, (maybe 3) decades ago. The problem with them is that CO is heavier than air and settles in them.................
If one were to go that route the cheapest/easiest thing would be to buy a pre-cast drainage/sewage box (hopefully new), dig a hole for it and drop it in. Any septic guy would be able to handle it for you. Then you'd need to duct in some fresh air and add a sump pump (depending on where you live). You'd also need someway to get in and out, even with a car above you (think how much of a pain that'll be to go up and down that ladder everytime you need a new tool, etc.) After all that I don't think you'd save much money.
#33
Range Master
Pepsie Lite
Pepsie Lite
Originally Posted by Bill Ball
Gretch:
G: No, actually my ceilings are more like 9 feet 7....The I beam height is about an inch lower than the total overall height of the lift uprights. When the doors are open, they are higher than the I beam.
G: actually the reason I went with the 2 post is so I could do brake and wheel work. The 4 post lifts generally are ramps you drive up on. Also they take up a lot of room at the corners of the bay.....where benches and tools go.......
G: Yep, that would give you more room. Mine are roll up automatic openers....work just fine.
#34
Gluteus Maximus
But if your primary use is working on the car get a 2-poster. It seems like 9 times out of 10 that I want to lift the car I want to take the wheels off too, and lifting the car off the wheels is more of a PITA with a 4-poster. Plus the 2-poster gives much better access to the bottom of the car (no platforms in the way) and you won't bang your head on it as much. Of the 2-posters, get an asymetric lift (lets you open the doors) and a clear-floor one if you can. It's so much nicer having a clear floor for rolling around on your creeper and rolling transmission jacks, drain tanks, etc.
Have you looked into doors which are hinged on the side (like a barn door)?
#35
Finally an instance I actually know something about!!
Mark: That would be nice, but mucho dinero. To do something like that takes alot more than just a hole, and the labor costs would be huge. First is the cost of breaking up the existing concrete with hand-held jack hammers & concrete saws, not too bad unless your house was built recently with tons of rebar in the concrete. Second, it would have to be dug by hand since you can't use most digging equipment unless your ceilings are about 12'+ and you're not worried about someone swinging that bucket the wrong way and taking out a wall. Finally, to shore up the walls in the pit, put in concrete forms around it and ventilate it properly (to protect against the CO instance mentioned above along with other gasses) in an already built situation would take alot of labor and special equipment. It would probably be in the range of $10K....in Georgia. In California (if it's legal) you can probably double that.
Something to think about the next time you're building a house. It's cheap then because they're already digging out the foundation and that's just a little hole to add. Ventilation can be added before anything is poured so it's just like plain old plumbing.
Oh, and I forgot to mention the almighty RED TAPE. I hear it's much stronger over there and costs a good bit more to get it out of the way.
#36
Range Master
Pepsie Lite
Pepsie Lite
Originally Posted by sublimate
I still see a few Quick Lube/Oil Change places with them and a lot of heavy truck bays still use them. My guess is if they are "outlawed", it's only in certain municipalities and only applies to commercial use or zoning regulations. More likely, OSHA frowns upon them or requires some heavy-duty ventalation for their use. Also I'm sure they're an environmental nightmare due to water inflow mixing w/ oil etc. .
In any event, in my opinion, they are unsafe as hell, and without some temporary, very strong cover over the hole, seem to be a larger compromise to the garage space than the 2 post lift does.
#38
Under the Lift
Gretch:
Yeah, I knew I must be dreaming about getting 2 cars in 8'. I must have misunderstood your comment about having the last foot of the lift go through the ceiling. Figured if the lift is 108", then your celing is 98" or close to 8'.
#39
Range Master
Pepsie Lite
Pepsie Lite
Gretch:
The lowest point in MY garage is about 106 inches from the floor........That is measured at the I beam that holds the two gantrys....for the chain falls. (orange thing in picture).
BTW, re the two cars, the difference between your ceiling height and my usable height is 10 inches. I believe there is more than 10 inches of space between my two cars, but the one on the bottom is a TR6. If I put it on the lift there would be more room between the cars......and oil on my C4.....
This is a great lift though, and quite easy to install. I wrote a thread about it when I put it in a few of months ago....
#40
My way down the road master plan is to eventually build a shop that has room for several cars and a lift for maintence....but I guess I would have to buy a house with a big enough yard first? Darn...that takes $$$$$$$$ away from my 928 fund! :>(
