Motor Mounts
Motor Mounts
I would just like to confirm that the mounts I am going to order the correct item :
Anchor 2698 Mounts for my 79.
I intend to buy from Rock Auto.
Thanks in Advance
Sean
Thanks in Advance
Sean
Hey Sean!
The 79' uses solid rubber mounts with a dampner. You cannot use the Anchor mounts unless you want to change the front crossmember also. The Anchor (Ford style) motor mounts are a direct (almost) swap for later cars that use the hydraulic mounts. The earlier ones are not compatible.
Dave
Motorsport
Dave
Motorsport
We had a choice?
Yep, Anchor are a no go on an OB. I bought mine from one of the Big 3. Just a paltry $145.00 each. Made a huge difference over the old separated ones. Worth $300.00? That's another thread.......
