View Poll Results: What is your Oil Change Interval?
2K miles
3
3.26%
4K miles
17
18.48%
6k miles
12
13.04%
9k miles
6
6.52%
12k miles
4
4.35%
Once a year
35
38.04%
Twice a year
12
13.04%
After every race
0
0%
Whenever...
3
3.26%
Voters: 92. You may not vote on this poll
Oil Change Interval
Oil Change Interval
Until recently I had my oil changed at 3k intervals, but a combination of laziness and reading Doug Hilary's posts has meant that it has been 12k since my last oil change (isn't that the factory spec OCI?)
Never Again. Not only am I not going to risk another Exxon Valdiz incident, but I'm never leaving it that long again. What came out was horrible, and believe me I've spent enough time wading through it to be sure that I made a mistake leaving it in the car so long.
Dean of Rennlist, "I'm Listening"
I change my oil once a year so far. But then I only drive the car 3-4K miles a year.
Once yearly.
Appearance changes during usage is a misleading guide to oil quality - the extreme visual may be a fresh change in a diesel: within a 100Km, some go to jet-black. Very small amounts of emulsified combustion by products start to look quite ugly, despite being well within the capacities of the detergent/etc. additive packages.
Every 6000-7500 is when I will be changing it once she's back on the road and the daily driver. That'll be about every 3-4 months. I believe the manual calls for 7500. In the Boxster, it's every 13-15K miles. The manual actually calls for every 15K with a filter change only every 30K, but I do the filter at every oil change in case there are metal fragments hanging out in there and waiting to get loose.
Mobil 1 has a new long-life that is guaranteed for 15K miles, no matter what the manufacturer calls for. Only problem is you have to use the Mobil 1 filter (if it's made for your car) and other filters don't last that long so you'd have to drain it anyway with the filter.
Since seeing the Consumer Reports tests a few years ago, I follow the manual. They drove 2 each of several different models 100K+ miles. One of each model they changed every 3K and the other when the owner's manual said to do it. At the end, there was no difference in internal engine wear.
Mine is a daily driver with about half the time in stop and go traffic. Also I have a few short trips per week, so it's every three months or 3K miles between changes.
Dennis
Dennis
Deer Slayer
2-3 K miles, Mobil1 only. The daily drivers: every 3500 miles, Mobil1.
I like clean oil and won't use anything but synthetic. I expect my cars to start when it's 30 below and the synthetic makes that a lot easier and a lot less damaging.
Under the Lift
Once a year or 10-12K miles for my 89. I just checked the manual, and it calls for 15K miles or once a year (7.5K miles for turbos). The 3K mile oil change is an oil company marketing program, unless you use cheap oil. My car is driven regularly (almost daily) and isn't left outside overnight (avoiding condensation). Do oil analysis if you aren't sure.
Originally Posted by UKKid35
I've used Injector Cleaner a couple of times, doesn't this quickly contaminate engine oil?
It is more likely any unburned residues blast out via the exhaust valve rather than being washed down the cylinder wall by the engine oil.
Sorry, I'm of the addage....oil is cheap...wear on the engine is not. That being said, my only concern is the natural oxidation and breakdown of oil over time. If you read the synthetic oil sites, they heartly recommend long change intervals, but I have a problem leaving oil in my engine longer than 4 months or 2500 miles. I'm probably wasting money, but at least I know that my oil is 'like new' and I'm adding an extra hundred or two dollars at most to my maintenance costs. Bottom line is, despite all the hoopla (me being one of the guilty) all of us who drive the car within it's limits have very few oil related problems. That just goes to show that large capacities and excellent engineering have made this car very forgiving on it's oil damage and wear.
Good driving,
Roland
Good driving,
Roland
Sharkaholic
Originally Posted by WallyP
Once a year, in the spring.
If I were storing the car for the winter, I would change the oil just before I stored it.
I store my cars twice a year, and change the oil in both right before I put 'em to bed. I also use dino oil as synthetic has a tendancy to drain off all the upper components and leave them unprotected during a long storage period.
