Help with interior air temp sensor
This weekend I'm going to perform timing belt surgery on my S-4 and also want to chnage out the cracked interior air temp sensor located in the middle of the dash. Anyone have any hints to help me in changing the sensor? It's that little roung thing with the slots.
Steve
Steve
Rennlist Sponsor
The hardest part is removing the Center Console, check Greg Nichols Tips Site for some great Instructions www.nichols.nu/tips.htm. Once the Console is out the sensor is very easy to replace, just a few screws, connectors and cable ties.
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
Under the Lift
I presume just the exposed plastic piece is broken. That is common due to expansion and contraction of the dash fracturing the ring that is tightly held and pressed into the dash surface by a strong tirewrap clamp behind the dash. The part is over $50 since the exposed plastic piece does not separate from the rest of the temp sensor device.
I replaced mine. PITA. Subsequently a clever engineer and 928er, Paul Jager, came to the rescue and developed an inexpensive, thin, black-coated aluminim button cut to look exactly like the eschucheon you want to replace, only new and unfracturered. Sticks right on top of the fractured piece and discreetly hides it. Looks perfectly original. You're done in a few minutes.
I was going to link to the item on Paul Jager's website at http://www.jageng.com but the site appears to be offline, I trust temporarily.
Under the Lift
Paul's site is back online. Here is the specific item. $36
http://www.jageng.com/tempcap.htm
Check out the whole 928 area for a lot of clever and nice stuff.
http://www.jageng.com/auto_1.htm
