Timing Belt Change
I just changed my timing belt on my 1990 928 S4 and during the change (5 years and 33,000km) I noted the the two bearing fitted to the 'Carrier for Tension Roller', the two rollers fitted under the crankshaft timing belt drive gear, both needed changing.
I removed the carrier and took the bearing out of the rollers and on removing the bearings (INA 6201RS) small shielded roller bearing.
I contacted my local Porsche Centre and the price for the replacement rollers was 22 times the cost of the new 6201 races.
I purchased the new 6201 races and It took about an hour to complete the job of removal of the outer rollers and fitting to the new ones.
I will now also look at replacing the ball races in the old tensioner rollers, so that I have spares to go with my spare water pump. which is still in good condition.
Hopefully this is good information for the DIY guys.
Tails 1990 928 S4 Auto
Well done - you will find that a #6905 is a direct press in for the water pump mounted idler: just be careful to measure the seating depth prior to pressing the old one out.
The # 6201s are nicely centered in their shells. For both, a drop of blue loctite can't hurt.
The tensioner roller is pretty much a specialized piece fixed to its shaft. I opened the 3 spots on the roller halves just for fun, looked inside - and then bought a new assembly: if you find an alternative, ......
