winter projects....whos doing what to theres shark
HI, report from a snow covered Sweden
Total renovation of the engine
New steering reck
New tires
Probably new eibach/bilstien package
New engine harness
Maybe msds heders
..and hopefully the snow vill go away in april...
//J
-79 928
-00 BMW 740dA (Grocery getter)
New steering reck
New tires
New engine harness
Maybe msds heders
//J
-79 928
Here's my list:
Fix slipping supercharger belt (Done 1/2)
Fix restrictive air intake (Done 1/2)
Mount I/C radiator fan (Done 1/9)
New Bellypan mounting bracket (in progress)
X-pipe and high flow cats (next week)
Full Roll cage (Feb)
Racing Seats (Feb)
New 5pt harnesses (Feb)
Fire Suppression System (Mar)
Oil Change/Radiator Flush (Apr)
Brake Fluid change (Apr)
First Race Bonneville 100 May 8th
Racing Seats (Feb)
-Motor Mounts
-Steering Rack
-Upper A-arm bushings
-Jager led light panel for pod
-Rad and heater hoses
-AC Compressor & recvr/drier
-maybe - Koni/Eibachs
all fluids
-Steering Rack
all fluids
I lost count of the length of my list.... One thing at a time, including driving as much as possible..! projected to be 70 Degrees and Sunny today already at 55.... Oh, wait, I'm in CA... That's normal.... Ok guys and gals enjoy the snow...
Let's see...
Renew brake/clutch fluid - done
Clean ABS sensors - done
Change both fuelpumps - done
New fuel relay - done
New drivers door lock - done
Repair door side - done
Test flappy valve - done
Test WOT/Idle switch - done
Degrease and pressure wash underside - done
Change front fule line hose - done
Oil+filter - done
Air+smog filter - done
Remove and check all fuses - done
Clean and treat leather - done
fix loose computer control arm - done
Repair AC switch - done
Fix rear speakers - done
Clean and grease cooler fans - done
Clean all ground points - done
Replace left rack boot - done
TB/WP and rollers
rebuild TB tensioner
New front brake discs and pads
New brake pad wear sensors
Remove intake powder coat
New idle air stabilizer
New right foglight
New door warning light
New caps/rotors/plugs
Maybe new wires
Adjust ride hight to original - in progress
RMB
As soon as my new service covers arrive intake and TB/WP work starts.
Propably forgot a few things but list is long enough to keep hidden from my wife....
/Peter
Oil+filter - done
TB/WP and rollers
New right foglight
Maybe new wires
RMB
/Peter
Deer Slayer
Install front Ott Sway bar drop links
Find *&^%$ vacuum leak (began playing with my little vacuum pump just 10 minutes ago)
Replace brake Fluid
Replace tranny fluid and filter
Buy and mount tires on spare rims
Motor mounts
Replace steering rack boots
That'll do for starters, since it's tooo cold to do any of it right now...
The nice part about that list? That's THE list, except for bling bling and fixing some piddly in the interior... then I can just drive that dog until something new comes up...
Replace brake Fluid
Motor mounts
Using the cold weather as well to get a few necessary things accomplished:
New 'cross-drilled' OE rotors
New OE pads
17" race rims with Kuhmo Victoracers for DE sessions
Switch to RedLine 5/40
Switch to synthetic gear oil
Replace resistor for fan switch
Brand New Leather...whoooopieee
Brand New Carpet....no more smell
Detail and P21S the exterior
Hopefully ready for the track...good luck guys and gals
91 GT Black/Cashmere
New OE pads
radiator out to fix leak on rubber seal between core and tank
driver door is stripped out while outside door handle does not work
shall I replace oil cooler hoses while rad is out?
fix minor leak under steering fluid tank
Upgrade S brakes and front suspension to S4 brakes and front suspension. Which means new lower balljoints, front wheel bearings, rotors, pads, brake piston seals (I'm powdercoating the S4 calipers yellow), and flexible brake lines.
My plans were to change the TB, water pump, change the intakes, repair the dash and put on the new shifter cup but since the turbo went south on the 931 I am still using it as my daily driver.
Dennis
Dennis
This procrastinator loves company Mine will be going on this winter also, among other things...
Originally Posted by Tom. M
- put on those nice red 8.5mm magnecore wires sitting in a box for a few months now..
later
Tom
midlman@rennlist.net
89GT
later
Tom
89GT
