So, How are the (rotor) holes holding up?
A word of warning..if you are running holed rotors...and moderately aggressive track pads (hawk blues in my case)....and drive on the street....the rotors will last less than 1k miles...
mine were toast after about 1 track event and about 700 miles of street driving. According to a spec sheet on the hawk blues (one that is not available on the web..)...the blues exhibit extremely high rotor wear rates when cold (ie..surmized to be street applications)...
If you run track brake pads.....swap them out for street brake pads for daily driving.......
Later,
Tom
midlman@rennlist.net
89GT
Later,
Tom
89GT
I have been running the Hawke HP+ pads with my cast hole rotors. Where do they fall in the color line-up ?????? Any rate, no wear issues with them, so I assume them to be a street oriented pad.
