Questions during TB change - updated w/Photos
Originally Posted by borland
......While you had the tensioner removed, that was a good time to replace the smog pump with a rebuilt one. You'll thank me later.
Bill - I checked the tensioner this morning and it's not leaking anything after turning the crank a few times to check...I will proceed with putting everything back together and watch for leaks...I'm hoping the tensioner was just over-fillled and I don't have to replace the gasket and boot again. I also filled it according to the instructions.
Thanks for sharing - Vasilis
91 S4 Black Auto
Originally Posted by athenian
Thanks for the tip....but I've never had a problem with the smog pump going on 86K miles now...No one mentioned to replace the pump while doing the belt. I will be listening closely for any noise coming from down below.
91 S4 Black Auto
91 S4 Black Auto
Smog pump job is easy, and my rebuilt cost $50 after core return. I bought mine at PartsHeaven (Unfortunately they are closed till Monday). I did a writeup on the swap here.
The price for the rebuilt I quoted was from 928 "Ubernational" catalogue. I will check my part number and contact your supplier.
