@#$%$# Bellhousing bolts!
Supercharged
Dave,
Are you able to get a length of pipe (cheater bar) on your wrench? I remember taking off the crank bolt. That SOB was on there tight. I ended up putting a 1/2" swivel-head breaker bar on the thing puls a 4-5' lngth of pipe (I was just shy of the hood). Even then it took a lot of huffing and puffing, but then it went. So I guess the moral of the story is, use mechanical leverage whenever you can, but if you can't then just forget about it and deal with it after you get the whole damn thing out with the bell housing in situ. Here's another reason to use anti-sieze! Makes everything... like butta. Let me know if I can lend assistance.
(BTW, got the caliper paint yesterday... don't know when I'll actually paint things, but at least I'm getting my ducks in a row!)
928 Engine Re-Re-Rebuild Specialist
Andrew:
I can get a wrench on the bolts now, but the edges are beginning to round off. I'm trying to avoid ruining them.
Supercharged
Then, I guess you should stop before things go from bad to worse. Let me know when you're ready to pull it, cause I want to be there (mostly for the pizza & beer though
928 Collector
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
![w_attention](https://rennlist.com/forums/graemlins/attention_whore.gif)
The next chance I get to wrench on the car will probably be tomorrow morning/afternoon. I'm going to take a stab at getting the connection between the bellhousing and torque tube loose instead of wasting more time on the engine block/bellhousing connections.
In my experience with this kind of problem, an even pressure to undo the bolt may not work. The bolt needs some sharp impact to break it free. Put a box end wrench on the bolt and then hit the handle with a hammer or heavy mallet.
The other thing that can be done is to apply loads of heat. The aluminum alloy housing and the steel bolt will expand and cool at different rates anf may break the bolt free.
Sean
Sean
Sean
Sean
P.S. I've developed a deeper appreciation for my magnetic telescoping arm after repeatedly retrieving a variety of 19mm wrenches.
Oh, and I've already got a set of these standing by in case I do manage to finish destroying the bolt heads...
![](http://content.sears.com/data/product_images/009/52162/00952162000-190.jpg)
UPDATE:
The 4 bolts holding the torque tube to the bellhousing are OFF, along with the 6 nuts holding the pinch collar to the flex plate. Unless someone tells me otherwise, it looks like I've successfully gotten around the need to remove the bellhousing bolts where it connects to the block.
USMarine
Originally Posted by sublimate
Maybe one of these would do the trick?
Yep, you are wasting your time and may even strip the bolt head
