How much fuel pres?
mOST EFI PUMPS will deliver enough for non racing use. eg my k-jet car (needs 75psi) has a single external pump from a later LH injection car on it, runs fine, deliver pressure and gallons/hr as needed. See if you can find a Bosch list of pumps and replacement numbers on the web....my theory is that (as long as its intended for injection) if it fits in the plumbing, it should do the job. YMMV of course.
jp 83 Euro S AT 48k
jp 83 Euro S AT 48k
You should have pump Bosch 0580 464 045 (current from 83-86 LH) according to Bosch, with no supercession or universal replacement. 928 intl list 580 464 017 for 80-86, which Bosch list as replaced by 580 254 053....
jp 83 S
jp 83 S
spare time... Specs say:
'84 L-jetronic & LH-jetronic :
2 bar, engine idle; or, engine off,
2.5 (+/- 0.2) bar, relay socket bridged
(& at least 1,150 cc delivery in 30 sec.).
G'luck.
G'luck.
