Map of fuse board
Map of fuse board
Hi,
I have some minor electrical problems in my 87 S4 - clock, cigar lighter, interior lights, tailgate release etc are all dead - and the fuse boars is my first port of call but someone seems to have pinched the chart listing what's what! Is there one I can access on the net?
Mark
(PS Never seen so many fuses!)
Mark
www.928gt.com
..left side: "tips /links"
..then..left side again...
"Specs &
Technical
Info Section"
its a handy thing to have if you dont have the original factory chart.
hey, your on thin ice asking so many questions here!
"Specs &
Technical
Info Section"
Thanks for the plug, Joe!
Here's a link.
[Edit]The 87 has a more complex fuse panel, with blade instead of torpedo fuses, but the principles should be the same. Only disconnect one wire at a time from the panel![/Edit]
Here's a link.
Check out the thread I started a little while ago about reverse lights. I had your exact same problems and they were all fixed when I replaced everyblade fuse with a new one and coated all the terminals with Stabilant. In my last post I believe, I gave the name of a place that carries it for an excellant price. Also, don't forget to pull the relays and clean their terminals also.
HTH
HTH
Dave-
Your advice good for the '85 model? I'm having the same problems with my mirrors. I'm thinking about buying the maint. manuals on disc, will all that be in there?
Adam
Adam
You won't find a procedure for this in the manuals. The 85 has blade type fuses, so the procedure will be a bit different in that area... but the fuse connectors should come apart with a dental pick or similar. If you are unsure, see if you can find a junk fuse panel to play with until you are sure you can disassemble the connections without damage. The biggest risk IMHO is getting too aggressive with the dental tool and deforming either the plastic or the terminal so much that it can't be reused.
