928 Forum 1978-1995
Sponsored by: 928 Specialists
Answer: "Why are the 928 Supercharger Kits so Expensive?"
Old 05-09-2009, 08:59 PM
  #31
Sailmed
Sailmed's Avatar
Location: In the boatyard installing the mast and engine, we don't need a crane, we harness the mesquito's! Yeah!
When dealing with confrontation out in the street - we tend to take the person who is screaming and yelling obsenities and put them in the back of the closest cruiser to tell their story...
Wonder why?
The ability to control oneself while telling the truth is a normal human function.
The lack of such control normally express's fabrication and denial of reality...
You have gained nothing and only alienated people from what ever cause you intend to prove.
Breath in grasshoper.....
IBTL x 928
Sailmed is offline
Old 05-09-2009, 09:37 PM
  #32
928SS
Road Warrior
928SS's Avatar
let's just say that it's very rare to see an aftermarket kit of any kind fit like a glove on every variation of vehicle.
and the more common the product, the higher the chance aftermarket stuff will fit and be at a lower price - due to volume and competition.
the 928 is a niche product. do the math. finding anything that is even close is a miracle 1/2 the time. I've had to fabricate for every after market part I've installed on my 928 from carl, 928 sp, devek and others.
just the way it is with a niche car and very few competeting vendors/products. but it usually beats doing it from scratch, so I'm fairly happy most of the time.
ya want near perfect fits w/inexpensive pricing - get a honda or mustang.
In My Opinion - if ya got a beef w/someone - starting out by being rational and specific is your best recourse. all the 928 folks I have purchased from have been fairly eager to help me out when we had issues w/their stuff. some were faster than others, but all eventually helped out.
if they don't and you think you have a case - go to court.
either way - name calling and harassing won't get you any results, so don't waste your time or ours.
928SS is offline
Old 05-09-2009, 09:55 PM
  #33
Droplink
Droplink's Avatar
Originally Posted by LV2FLY
That's a good question guys. I can'y figure out how 928 Motorsport takes a $2.45 made in Korea bearing and jacks the prie up to $250.00. You can buy the correct Powerdyne bearin a made in the USA KBC bearing for you impeller shaft for about $17.00. Write me at brad.allore@yahoo.ca and I'll give you the KBC part number. By the way the 928 Impellers are **** & crack.
Brad
Aircraft Engineer
Carl Fraud is the biggest liar on the internet. 928 products and suport is Jack ****! I can prove it.
Me thinks someone's rhubarb got rubbed the wrong way. Yikes!
Droplink is offline
Old 05-09-2009, 10:09 PM
  #34
Warren928
Warren928's Avatar
The moral of the story: Never trust a guy with a lime green pickup truck.
Warren928 is offline
Old 05-09-2009, 10:32 PM
  #35
ew928
Owns the Streets
Needs Camber
ew928's Avatar
Brad
Aircraft Engineer
Have you tested the bearing to see if it has been modified as Carl said he does to the bearings. Or are you just going by the number/ID stamped on the bearing shield.
Just wondering.
opcorn munching smiley:
ew928 is offline
Old 05-09-2009, 10:56 PM
  #36
RicerSchnitzzle
RicerSchnitzzle's Avatar
Brad
Aircraft Engineer
Carl has already said you just need to send back the bad impeller for him to check to see if it's covered under warranty. Just like any other retailer would. If you sent it in and he didn't take care of you then you'd be able to bitch. However expecting ANy retailer to replace product with pictures and no return is just retarded.
Try taking pictures of you bad alternator to AutoZone and ask for a replacement with out returning the actual item. Quit being a tard and just send Carl the impeller. Then if he mistreats come bitching, until then quit being a little bitch.
Sounds good. We're listening...
ban in 3.. 2... 1...
RicerSchnitzzle is offline
Old 05-09-2009, 11:03 PM
  #37
aggravation
aggravation's Avatar
Aren't you the guy who dropped his blower and demanded a refund while refusing to send it back, as per the warranty agreement, so the vendor could see if the part was really bad...or dropped by an idiot?
aggravation is offline
Old 05-09-2009, 11:09 PM
  #38
Tampa 928s
Tampa 928s's Avatar
This has taken a whole new turn
Tampa 928s is offline
Old 05-09-2009, 11:12 PM
  #39
toofast928
toofast928's Avatar
Proof of Carl's products are in the the dyno.
Last year cranked out 405 HP on the using Carl's Powerdyne & impeller. This year maybe 430. I can prove it by posting my dyno sheet!
Tony
928Motorsports Supporter
toofast928 is offline
Old 05-09-2009, 11:30 PM
  #40
Andre Hedrick
Rest in Peace
Andre Hedrick's Avatar
Brad
Aircraft Engineer
Since you are a bearing "expert", just have to ask ... why did you not contact Carl and ask about the bearing in question before installation?
Why will you not send the impeller back under warranty review?
IIRC the KBC number was on your eBay slam page.
What year 928 do you have?
Andre Hedrick is offline
Old 05-10-2009, 12:12 AM
  #41
SeanR
SeanR's Avatar
It sucks that the e-bay auction has been pulled. I wanted to buy it. Might be as close to having a supercharger on my car, even if it is just the impeller mounted on the oil fill cap.
SeanR is offline
Old 05-10-2009, 07:29 AM
  #42
Mike Frye
Craic Head
Mike Frye's Avatar
I wish I had saved the pic of the broken impeller. As I remember it, it was a great close up of the inner part of the turbine, but didn't show the end of the same fin. My guess is there was also damage to the outer end of it that will clearly show that it was damaged (dropped or machined or something). If he's so paranoid that Carl will do something to it after he gets it back, the pics of the whole thing should be enough to prove his case in court if it got to that.
Does anyone else think maybe this guy and his engineer buddies were trying to re-engineer the design and can't figure out how? He keeps asking for specifics of the design and even says that Carl can't touch him because he's in Canada.
If he thought it was a bad design he should have sent it back for a refund immediately. If he thought it was a good design initially and installed it then he should STFU and comply with the manufacturer's return policy.
Somebody show this clown the door please.
Mike Frye is offline
Quick Reply: Answer: "Why are the 928 Supercharger Kits so Expensive?"
