928 Forum 1978-1995
Sponsored by: 928 Specialists
What oil in gearbox is best?
Old 10-30-2004, 05:01 PM
Peter F
Peter F's Avatar
Default What oil in gearbox is best?
What oil should I use in my gearbox?
It is a 1990GT and has PSD, do I need any addins for the differential lock?
Cheers/Peter
Old 10-30-2004, 05:11 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,075 Likes on 1,184 Posts
I'm trying out Royal Purple - all the necessary certifications - additives for limited slip already in there.
First track event - five 20 minute sessions, my transmission shifted like silk each time. This on an US 81 with 93,000 mile original syncro's. I'm not trying to pass it off as "the best" but so far so good in my car.
Old 10-30-2004, 05:20 PM
Thaddeus
Deer Slayer
Thaddeus's Avatar
Every time I see that avatar, HP, I start laughing. The expressions on their faces... the man and the dog both... you're killing me here.
Old 10-30-2004, 11:53 PM
mspiegle
mspiegle's Avatar
i switched out my incredibly old oil from the PO to new M1 synth, but didn't notice a whole lot of difference.
I think I want to try RP just for kicks... maybe i'll get lucky and have as good of results as HP
Old 10-31-2004, 09:49 AM
Dave Sz.
Dave Sz.'s Avatar
Hacker,
Where did you get your Royal Purple from?
Dave Sz.
89 GT
88 S4
80 Euro S
Old 10-31-2004, 06:06 PM
H2
H2's Avatar
Thaddeus,
Where do you get your great art work from? I like it but I think it would haunt my wife....on second thought....maybe that's not a bad idea!
Harvey
Old 10-31-2004, 07:27 PM
Mark
Mark's Avatar
The Redline is highly touted. It has a buffer or something in it that's supposed to be real good.
Old 10-31-2004, 07:57 PM
IcemanG17
IcemanG17's Avatar
In some of my previous cars I have had good luck with Redline transmission oil. Specifically the car had a balky third gear syncro under full throttle upshifts...after putting in the Redline it shifted smoother and the balky third gear was back to normal!
Old 10-31-2004, 10:15 PM
hacker-pschorr
Corvette Sports in Sheboygan Falls, WI. They stock the gear lube, use it on most newer Corvette's. I don't know what they charge per bottle since I also picked up two cases of RP oil at the same time. I didn't bother to break it down. 920-467-2833, if your not too far from Sheboygan, it's worth stopping in. They always have beautiful 60's Corvette's in various stages of restoration. The owner and my father have known each other since the early 70's. Tell them you talked to Erik.
Old 10-31-2004, 11:30 PM
Abby Normal
In Your Face, Ace
Abby Normal's Avatar
Anybody using Swepco? This is something I'm about to have done and would like to here some comparisons. I have used Royal Purple Motor oil and have always heard great things about their products.
Old 11-01-2004, 02:53 AM
Joe F
Joe F's Avatar
I switched to Swepco in my 83 euro S. I can't say I could tell much difference. I think I am going to try some amsoil in there next change. I have heard that it will make a marked difference in the 1-2 and 2-3 shifts. Even when cold they are supposedly much smoother. My car has a very recently rebuilt trans so I don't have problems with the synchros, but the shifting is still kind of notchy. I thought the swepco would help that, but it hasn't seemed to.
YMMV
Cheers
Old 11-01-2004, 04:51 AM
drnick
drnick's Avatar
i noticed a real difference (improvement) from cold at startup when i changed from dino to synthetic - some unknown brand with the correct ratings.
Old 11-01-2004, 08:50 AM
Doug Hillary
Doug Hillary's Avatar
Hi Peter,
this link may help you;
http://www.landsharkoz.com/techtips.htm
Check under "Lubricants for the 928"
Regards
Doug
Old 11-01-2004, 09:24 AM
hinchcliffe
hinchcliffe's Avatar
Has anybody tried Amsoil 75w-90? I had the Redline in my previous '87 w/ LSD and it seemed to be pretty good stuff. But I'm going to try the Amsoil this time.
Old 11-01-2004, 09:55 AM
Dave Sz.
Dave Sz.'s Avatar
Thanks for the info. Hacker
Dave Sz.
89 GT
88 S4
80 Euro S
Quick Reply: What oil in gearbox is best?
