928 Forum 1978-1995
Sponsored by: 928 Specialists
Leda Suspension Group Buy
Old 10-25-2004, 04:48 AM
Rehan
Rehan's Avatar
I'm considering the Leda coilovers. A few months ago I drove a raceprepped 944 NA with Leda suspension and that car was amazing
From what I understand the dampening is adjustable without removing the dampers.
From what I heard the Leda guys a quite knowledgeble and they know what they are doing. The seem to have a good reputation I've never heard anything bad about Leda shocks, except that they can be a bit noise some times.
It would be nice with some more information though.
Old 10-25-2004, 01:59 PM
BC
BC's Avatar
The Bloke is having some "951 community" issues over on that board. So much energy gets wasted over there - it amazing they get anything done. I've emailed him for a response - I'm sure he'll come through.
Old 10-26-2004, 08:30 AM
Garth S
Garth S's Avatar
I had a helpful conversation with LEDA this AM - so perhaps this can clarify some points re. the 928 application. My questions centered only on catalogue # V0201, the oil filled dampers for the 928 @ GBP 837.
- all dampers/shocks are made to order with a typical 3-4 week delay
- damper end fittings/attachments are as per customer order (heim/rose/etc. joint), so for a 928 I suspect they require a used set of Boges to work from.
-there are some errors in the catalogue listing; apparently, it was assumed that 928 had 944 style rear torsion bars not requiring coil-overs, for this came up several times.
a) the V0201 price is dampers only! They are @253/fr, 172.5 rear, or GBP 851 the set of four - GBP 14 error re. the 837, no big deal.
b) the Eibachs are separately priced @ GBP 50.25, or ~ GBP 200/set - and to repeat - are not included in the GBP 851 price.
- the Eibachs used are flat seat, linear springs of 2.5" id front, 2.25" id rear.
- the 24 position valving is said to be quickly adjustable externally - and can accommodate driving to the Country Club for dinner to aggressive track use: This would be one of the strong points IMHO.
Anyway, for the 928, it would seem that shocks w. Eibachs list at ~ GBP 1050: A group buy as Tommo is kindly promoting would knock ~30% from that to 735. VAT of 18% can be avoided on export if you are clever, then there is shipping, Customs/Excise. The $US/GBP current exchange rate is ~1.84 - which would be ~ $1352 US/ $1654 Cdn.
What I've read of this set up on 911s etc - the Ledas seem to be a great set up; however, for our 928s - it is not quite 'off the shelf'. To be fair to Leda, it does seem that with very little effort, they would have the correct attachments fitted to the dampers - and it would be a most attractive suspension at a slightly higher price ( 200 -30% for the Eibachs).
Perhaps this will add some facts to the unknowns raised - they were very pleasant folks to talk to, and would be most helpful to proceed.
Old 10-26-2004, 08:47 AM
Rehan
Rehan's Avatar
Garth,
Great info! I'm a a bit confused about one thing, does this mean that we have to send them a core to start off with?
Old 10-26-2004, 08:55 AM
Garth S
Garth S's Avatar
Originally Posted by Rehan
Garth,
They would seem to need a dimensional spec for the 928 shocks front and rear, at least fo the length, stroke and end fittings: If that is not readily available to Leda, it is my speculation that a typical Boge fr/rear shock would tell them all they need. I didn't persue the topic past that point, although a core sounds like the most practical thing.
Old 10-26-2004, 09:36 AM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,204 Likes on 1,243 Posts
Originally Posted by Garth S
it was assumed that 928 had 944 style rear torsion bars not requiring coil-overs, for this came up several times........for our 928s - it is not quite 'off the shelf'. To be fair to Leda, it does seem that with very little effort, they would have the correct attachments fitted to the dampers - and it would be a most attractive suspension at a slightly higher price ( 200 -30% for the Eibachs).
This seams to address Marc@Devek's question - these have never been installed or tested on a 928 before.
Old 10-26-2004, 09:43 AM
Garth S
Garth S's Avatar
Hacker,
That may, or may not be true - They list many dozens of applications in literally hundreds of variations: I did not persue the conversation to confirm direct 928 experience with the Tech guy who fielded my call.
Old 10-26-2004, 10:10 AM
stuartph
stuartph's Avatar
Guys
I'm about an hour away from the leda factory in the UK, if they did need to see a 928 for specs etc i dont mind going along, plus i'm very tempted in getting a set but was planning on getting my suspension done next year as i have other projects in the way first.
Stuart
GT UK
Old 10-26-2004, 11:02 AM
Rehan
Rehan's Avatar
Stuart, that sounds great!
I'm very tempted getting a set myself but my wife is not so happy about it At 640£ plus 17,5% vat she could barely accept it.
I was thinking why don't we organize a group buy ourselves. Stuart is tempted and some of you US guys to. So if we could get at least 5 persons then it's 30%off. This would buy me some more time to convince my other half that we actually need these coilovers
Old 10-26-2004, 01:49 PM
BC
BC's Avatar
1300 or more puts me out of the ballpark - I already ordered and have just recieved my Konis. I was thinking that a package for over a grand would be comparable to me getting eibachs and these konis for ~950 plus finding hardware.
Old 10-26-2004, 02:02 PM
BC
BC's Avatar
A lady namedBeverley on the 951 list has come forward as a rep of LEDA in the UK. She is sour on a group buy for the USA as there is already a "master distributor" for LEDA here.
Old 10-26-2004, 04:47 PM
BC
BC's Avatar
Hey all - I added to the thread over on the turbo 944 list and asked Beverly some questions - hopefully she will have time to respond here or there....
I said:
Bev - could you come over to the 928 thread for a moment and answer some of the questions that Tommo has not had a chance to?
A gentleman from that area has already called your business I believe. There may be more questions still though.
The issue with springs being extra from the prices (and thereby the group buy discounts) listed - can you verify this?
The 928 is heavier then the 944 obviously, and we would need, for street use, ~400s for the front, and ~300s for the rear, with alot of height adjustability. I couldn't even say how long the spring should be....
The rear shock on the 928 also has a sort of "kink" or "bend" in the weld for the lower bolt-joint. This is obviously because the shock is not fully perpendicualr to suspension travel. Would the LEDA units have this?
Thanks,
Old 10-26-2004, 05:58 PM
drnick
drnick's Avatar
i would be wanting a stiffer spring rate at 600 front and 400 rear as per deveks hypercoil coilovers. i have the eibach progressives on my 86 and they are great for an aggressive street car around town but i think they could do with being firmer.
are these shocks two way ajustable, that is for bump and rebound? i think we probably do have enough interest to initiate a group buy and it shouldnt be too difficult to get a couple of dead cores sent to leda, here in the uk, for them to measure the physical dimensions.
Old 10-26-2004, 06:14 PM
Jim bailey - 928 International
Jim bailey - 928 International's Avatar
Nick the Eibachs are 399-559 lb fronts and 285-372 lb for the rear progressive but the 2,800 -3,400 lb weight of car compresses the springs into the higher rates when static while allowing more loaded travel in rebound than a short stiff spring which simply extends fully under wheel droop and is under no load rattling around.
Old 10-27-2004, 05:05 AM
drnick
drnick's Avatar
jim, i really like the eibachs and they improve the ride substantialy to the point of making the car into a real sportscar however i have had them bottom out a couple of times and am left with the feeling often in high speed runs of wanting something stiffer, especialy for the front end. having said that i also think that if i get what i want i wont enjoy driving in the rain quite as much, or over bumps at all. i would be putting this uprated combo into my SE which dosent get driven as much as the auto.
extrapolating from the eibach rates, 600 on the front would be a noticeable difference as would 400 in the rear. i think mark kibbort recomends running regular front springs in the rear and uprating the fronts to around the 600 mark.
Quick Reply: Leda Suspension Group Buy
