Nitrous question
I was thinking about this as well. The wet system seems so much easier - but how would the cold start valve placement be the best for atomization? Wouldn't the ront cylinders get more then the rear in this setup?
Maybe a bar fogger setup. It could go across the whole spyder.
Inventor
airosey,
I'd sell the modified rail and Teflon hose for $30. Add $20 for a used injector. (+shipping)
BrendanC,
Is a bar system just a tube with holes drilled in it?
The hole in the front of the plenum is large, ~3/4", so putting one or two tubes through there would be easy.
BrendanC,
Then guy that does your injector cleaning will flow-rate the thing once it's cleaned and refurbished, and you'll have the actual number for your piece. Just remember to ask him to get you the number.
