Chroming Plastic
Does anyone know a place where you can get plastic parts chrome painted...if that is actually the process? I have tried the off the shelf paints at the auto stores and they are nothing more than bright silver....more aluminum looking.
Under the Lift
Yes, Keith, plastic vacuum metalizing is available. It actually uses aluminum but shines like chrome, unlike the paints you found. The aluminum is vaporized in a vacuum and deposits as a thin layer on the plastic, then is topcoated to preserve the shine. I googled a service in your area:
http://www.finishing.com/Shops/mmmetalizingsales.html
Bill this just might make you a co-dependant ......remember the front, rear bumper covers are PLASTIC , Air cleaner housing , fan shroud .....
Whoa...Jim, you're freaking me out! You may be on to something there. Doesn't chrome make you slip through the atmosphere quicker?
Thanks Bill! I will contact them.
Under the Lift
Egad. I should have kept quiet.
Keith, put down your tools and step away from the plastic pieces before your car will ends up looking like a mid-60's Chrysler.
Supercharged
Keith-
Blingidy 'da bling bling wit 'da blingy blingy 'da bingidy bling bling! BLING! But don't forget about the bling. Plastic bling makes 'da blingidyest bling 'da bling bling. If only rubber bling bling would bling bling 'da bling bling, 'den you'd hab the BLINGIDY BLING BLING der ever was!
Administrator - "Tyson"
An aluminum (look) belt cover would be cool.
Keith, while you check into that place for the chroming of your parts, find out if they do the simulated aluminum..titanium...brushed steel etc etc coatings on plastics that are common in todays newer cars.
Im still trying to figure out what your "chroming" on the GTS???hmmmm
