Light Bulb Replacement? A/C On Button and LED Progress
Anyone replace the light bulb behind the "A/C On" button? Does the **** just pull off to expose the bulb?
I'm still working on interior lights that I want to replace with high brightness LEDs.
On the red door safety lights, the red lens just pops off. No need to remove the door panel. The 2 watt bulb there is a "Ba9s", easy to removed with the sticky side of a post-it note stuffed inside the cavity and a given a twist. I found some 4 LED replacement bulbs that are supposed to be brighter than the 2 watt incandesent bulb.
