928 Forum 1978-1995
Sponsored by: 928 Specialists
oil breather exhaust vent system
Old 09-16-2004, 02:16 PM
  #31
Tony
Tony's Avatar
Well,
from my head, to the card mock up..to a chunk of metal!
Im pretty damn proud of myself actually! This is what enjoy about this SC thing. It should work OK i guess.
I added a copper scrubber to the top, then sealed it in using aluminum wire mesh sandwiched between the two halfs of the assembly. With 4 tack welds on each corner, nothing is going anywhere. I ground down all my welds and it actually looks pretty good!
BTW..if there is anythign wrong with it. I dont want to know. Im done messing with it!
Old 09-16-2004, 02:39 PM
  #32
heinrich
928 Collector
heinrich's Avatar
Tony ... pot scourers, when I've used them ... they've always left little pieces everywhere. I wouldn't put them into the engine ....
Old 09-16-2004, 02:45 PM
  #33
bcdavis
bcdavis's Avatar
They have plastic pot scrubbers, with the exact same consistency and texture. Wouldn't one of those work just as well as the metal ones?
Old 09-16-2004, 02:47 PM
  #34
heinrich
928 Collector
heinrich's Avatar
melt.
Old 09-16-2004, 02:54 PM
  #35
heinrich
928 Collector
heinrich's Avatar
Tony where did you find Sasquatch and how did you teach him to hold that part? ... Kidding Man
Old 09-16-2004, 02:59 PM
  #36
bcdavis
bcdavis's Avatar
DOH!
Old 09-16-2004, 03:00 PM
  #37
heinrich
928 Collector
heinrich's Avatar
Old 09-16-2004, 05:46 PM
  #38
Tony
Tony's Avatar
Gee, thanks Heinrich. But ya know, Id rather have the hair on my arms than on my back
Old 09-16-2004, 05:50 PM
  #39
Gretch
Range Master
Pepsie Lite
Gretch's Avatar
Received 1,235 Likes on 755 Posts
I am crying here, Tony...........errrr "Sas"
Old 09-16-2004, 05:59 PM
  #40
heinrich
928 Collector
heinrich's Avatar
... sheesh I was beginning to worry that you were taking me seriously Dude ... HAHAHA!!!
Old 09-16-2004, 06:01 PM
  #41
heinrich
928 Collector
heinrich's Avatar
Anyway that back hair sure helps while I lie under my car hour after hour ....
Old 10-07-2004, 04:03 PM
  #42
Tony
Tony's Avatar
Well, this is what im going to use. Its used in aircraft. However, i wont be paying the 300-400 bucks Ive seen advertised for the stupid thing. Ive seen the crossection of one after it was ran through a band saw. I will build it my self...yet another "fab" project!
Thank the words FAA and STC for the price..insane for what it really is!.
I love when a plan comes together.
Its done and has just been test fitted. All fits neatly next to and slighlty below the brake resivour/booster area. POIFECT!!Now i get to grind the welds down and add a dose of black wrinkle paint. Took all but 15minutes tops to get welded up. I stood there and held the parts as they were tacked.
And it DIDNT cost me 300-400 bucks either!
Old 10-07-2004, 04:39 PM
  #43
Jim bailey - 928 International
Jim bailey - 928 International's Avatar
Tony you are having way too much fun with this !
Old 10-12-2004, 07:11 PM
  #44
Fastest928
Fastest928's Avatar
I have used one system for years, and recently, tried another "route", and pumped out about 1 full qt of oil...some onto the headers.............not a pretty sight...
Using the valve covers as part of the breather system is not the best way to go. I have also used the oil filler neck with not much better results. Each will produce about 1 pint for each half hour racing. I am working on a system to reduce it to zero without dumping it into the exhaust...although the easy way is becoming attractive!
A DeVore/DEVEK dry sump, as used on other dry sumped 928 racers, is set for the next engine revision.
Marc
DEVEK
Old 10-12-2004, 09:28 PM
  #45
Tony
Tony's Avatar
Marc
DEVEK
Well, i guess i will see. Others seem to be having success with there home made breathers, besides, this isnt a race engine in a race car used for racing YMMV.
Quick Reply: oil breather exhaust vent system
