Water Temperature sensor install
really requires that you have the water "bridge/manifold" out for the install due to the shavings.
1) Autometer electric water temp guage of your choice (1/8 -27Npt fitting)
2) an 11/32 drill bit to drill the hole
3) 1/8-27npt tap
4) a vice and a steady hand!
5) and probaly some thread sealant for good measure.
It took me all but, oh, 20minutes to install this? There is a nice flat area just aft of the the small coolant line. See pics.
Living in Vegas here and installing a SC i wanted to have a better indication of what the engine temp was. Now i should be able to relay to you all what point on the "stock" needle is what temp!
next, oil an tranny temp.
HTH
Does that look right?
3) 1/8-27npt tap
HTH
Looks good Tony.
Are you going to install air temp sensors in the manifold too?
Man.... you gota get that system on already. I think some of you guys may be just kinda afraid of how fast your cars are going to be.
Let me kinow if I can help with the tanks and such you need welded. I am getting a bunch of .125 and .063 aluminum water-jet cut tomorrow, and will be visiting the welder later this week.
Andy K
Andy K
