Proper accounting of US and Euro 16V HP/TQ@RPM?
Originally Posted by PorKen
How/where did you collect the numbers? Did you convert some from ft.lbs?
Porken
'83 S Euro specs directly from my owners manual
Motor M 28.11/12
Bohrung .................................................. 97 mm
Hub ...................................................... 78.9 mm
Hubraum tatsachlich ............................. 4664 cm
Verdichtungsverhaltnis ............................ 10 : 1
Motorleistung nach DIN ............................ 221 kW (300 PS)
Bei Kurbelwellendrehzahl ......................... 5900 1/min
Drehmoment nach DIN ........................... 385 Nm (39.2 kpm)
Bei Kurbelwellendrehzahl ......................... 4500 1/min
you may also need this number....
Zundgrundeinstellung............................... 26 degrees vor OT bei 3000 /1min, ohne Unterdruck
Hope this helps.
cheers
Motor M 28.11/12
Hope this helps.
cheers
Inventor
Paul D.
Excellent, thank you!
Vilhuer,
Tack så mycket! (jag kan ju inte finska
Joe F,
Danke schön! I was just thinking about how the ignition advance would be another good data point.
Anyone have the 78 or 79 US and ROW and 83 or 84 US glovebox manual graphs?
I will reformat the cam/engine info and graphs and put it into a web page.
Vilhuer,
Joe F,
Vilhuer,
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
http://www.alessandromaccari.com/art...oodreasons.pdf
Administrator - "Tyson"
vilhuer - About 90% of those apply to Wisconsin as well
