Murf928 SuperShark update
Andy, I won't say that fatter rails are not bad. But, if they are bad, surely it cannot be for the reason you write above? We are not talking about a constant mass of gas at steady-state that obeys PV=nRT inside a rail that changes its volume dynamically.
Sure, it takes longer to build the pressure from zero to the desired pressure because more fluid mass is required by the larger plenum and the mass flow rate from the pump is more-or-less constant. But, once at the desired pressure it is a matter of mass entering vs. mass exiting.
I don't buy the lower pressure argument on rail volume size though.
It may very well be that the plenum volume required to make a useful difference in managing a transient fuel pressure gradient is so great as to be impractical.
Conversely - although Porsche made the individual injector lines on the CIS cars so little - they got bye with that because they shoot continuously.
Funny how you 32v guys are swapping fuel pumps and increasing line sizes.... very, very much down the same road I am going with my track car (read: EXPERIMENTAL CAR). Our 16v Stage 1 and 2 kits have enough fuel, but the race car - I am trying to find more fuel for it as I turn up the boost.
Here's a picture of those larger fuel lines - they helped - but I think I have a "maximum flow potential" problem stemming from the ***-end of the car that I am trying to work on now.
I am glad you know more than RC Engineering which is probably one of the premier FI shops in the country. EDIT: I went to their site and they claim to be the best in the world.
The Lightning rail is NOT the same size as the line to EACH injector. ALL injectors share the same rail and that rail is NO bigger than the fuel supply line in our cars. Can you not see that in the picture? END EDIT
Regardless of the firing order of the Lightning injectors, the same amount of fuel has to flow to make the same amount of power.
Maybe you could answer this. Why is it that the curves on Tim's last dyno chart posted cross at 5750 instead of 5250?
Thx,
Andy
Tim:
And you guys wonder why I don't follow this stuff or post anymore?
Carl:
You make everyone think that you're a CIS guy, and then you make a post like that stating one of the differences between sequential and batch fire EFI?
Jim:
I don't want to tell you how to do your job, but it might not be a bad idea to check your piston inventory. No matter who's right, it seems like you may very come out a winner. $$$$
Andy:
Well, download complete so...
T = (5252 x HP) / RPM
At any point in time, if RPM = 5252, then it will cancel out the 5252 on top, and you are left with T = HP. That is why T and HP cross @ 5252 - because they are equal.
Are you saying that this equation is wrong?
I kinda like Jim Baileys observation about the CIS cars having a pressure accumulator and the EFI cars not - as he says, it holds about 1/2 cup of fuel under system pressure to release so there is no system "make up" lag under sudden WOT. Interesting...
About this whole volume vs. pressure conversation: a common trick engineers will use in fluid systems when it all gets too confusing is to convert the equations as if it was electricity. Use Volts (pressure) Amps (volume) and Ohms (resistance) - in almost every way, the elctrical analogy is a perfect match and will behave the same as fluids.
Can two wires - a big one and a small one - carry the same volts, but have different amp capacities? Of course.
Will the smaller wire resist a drop in voltage when the "juice" is on better than the bigger wire? Hell no.
Does this help?
You could all just drop the fuel pressure down and go with a much bigger injector. Your pump and injectors will be much happier in the end!
The 5252 comes directly from the fact that there are 550ft-lbf/second in one HP and the fact that there are 2pi radians in one revolution and 60 seconds in one minute. 550/(2*3.14/60)=5252. It is a unit conversion. Perhaps we all need to start plotting in Newtom Meters and KW? In the end the highest torque across the entire range will build the most HP across the board. I'll take the setup with the higher torque across the entire RPM range any day over higher peak HP with less "average" torque.
And the boost wars continue...
At any point in time, if RPM = 5,252, then it will cancel out the 5,252 on top, and you are left with T = HP. That is why T and HP cross @ 5252 - because they are equal.
Andy K
Andy K
As long as I get that commision on kits that are sold, and not just on ones that are installed kits.
Welcome back Z. It's good to see you. Every time you show up someone buys a kit from me. Come around more often and maybe I'll get this on rennlist , by rennlister, for rennlisters venture paid for one day. I guess it would be smart to commission you as I would pay it off faster. I don't think a bank would cash a check made out to someone named Z though. Who should I make the check out to? I guess I'll need to pay your Rennlist membership too. You would have to give up your name for that though.
Andy K
So Andy, with all these supercharger kits that you have been selling we are all wondering when we will actually hear about someone getting one installed. I am only aware of one person on the list that was installing your "kit" and that person stopped reporting his progress over a month ago. You claim to have sold more than twice as many kits as I have and I am wondering why we haven't heard of any results yet or testimonials from any of your customers. Maybe they are just a quiet group like the FAST guys perhaps?
Guys....Guys....
Go to your nuetral corners!!
Obviously, the MURF kit is complete, with full instructions, testimonials, and dyno results.
Andy's kit is more of a do-it-yourself thing.
It is probably taking people longer, because of that fact.
They have to source parts, get things figured out, etc...
With the MURF setup, you just bolt it all on, and go...
But you pay for that...
People are willing to wait for Andy's parts, and wait for the instruction manual, etc, because they are saving quite a bit of money...
